Hi-temp Engine Paint For Wheels??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si »</TD></TR><TR><TD CLASS="quote">Gloss black is the color. I'm not really interested in using caliper paint because it's to damn expensive for what you get.</TD></TR></TABLE>
Engine paint here. It works, for a little while.
Don't count on it lasting.
Probably better off with regular body paint, it can stand the heat under the hood so it should do "OK" on street wheels.
-Chris
Don't count on it lasting.Probably better off with regular body paint, it can stand the heat under the hood so it should do "OK" on street wheels.
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si »</TD></TR><TR><TD CLASS="quote">thx for chris F I'll pass on the engine paint then. I'll either go with regular duplicolor enamel or rollbar paint.</TD></TR></TABLE>
I've used the dupicolor wheel paints with good results, just make sure to do a good job prepping the wheel first, and the paint will stick nicely.
and last time I checked they did have a gloss black.
i used high-heat enamel. worked well.. you just have to scrub the rim with steel wool to make sure ALL the oil/grease/debris is off. not really a use of taking the paint down with airplane thinner - very time consuming. just make sure to primer it right and it should all be good. good luck.
btw - paint does chip off from rocks..
i painted my old hx wheels with high temp paint and it lasted without chippin. just make sure you do a good job preppin like everyone said. i mean it'll eventually chip from rocks. but mine stayed good for over 6 months easy.
R-Toyz.com
Paint and Body
14
Jul 5, 2007 08:34 PM
H.crx-si
13
Jul 7, 2005 06:57 PM
kefka
16
Apr 10, 2003 03:23 PM
