Kinda poll- what kind, size of turbo do you use in your preludes?
Old Jul 5, 2005 | 01:48 PM
pentaq's Avatar
Default Kinda poll- what kind, size of turbo do you use in your preludes?
I didn't want to ask everyone separately, so I decided to make a new thread.
The question is:
what type, size fo turbo do you use in H22 Ludes?
When does it get a full spool?
Power/torque estimates would be helpful too.
thanks
Old Jul 5, 2005 | 06:03 PM
bubs's Avatar
Default Re: Kinda poll- what kind, size of turbo do you use in your preludes? (pentaq)
I've got a Borg Warner/IHI T3/T04e on my 97' SH.. It's got a .60 compressor and .70 turbine.. 54 trim wheel. With my crappy restrictive exhaust, I make full boost at ~3,500 rpm, it will spool much quicker when I get a different exhaust.
Not sure on power estimates, it's not real high with my stock exhaust, but when I had an open downpipe, the butt dyno told me it was in the 240-250 whp range on 6 lbs. of boost.
Got it from http://www.blaastperformance.com.
Old Jul 6, 2005 | 05:55 AM
pentaq's Avatar
Default Re: Kinda poll- what kind, size of turbo do you use in your preludes? (bubs)
bump
Old Jul 6, 2005 | 10:15 AM
graphic's Avatar
im using a t3/t4oe 60 trim compressor w/ a .63a/r hotside and t31 turbine wheel
i made 380whp/320tq off 18psi on a stock head...
i hit full boost at 4400rpm
here
Modified by graphic at 7:33 PM 7/6/2005
Old Jul 6, 2005 | 12:27 PM
eMpAtHy's Avatar
Default Re: Kinda poll- what kind, size of turbo do you use in your preludes? (graphic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic &raquo;</TD></TR><TR><TD CLASS="quote">im using a t3/t4oe 60 trim compressor w/ a .63a/r hotside and t31 turbine wheel
here
looks like a nice tune. the torque and hp lines are almost flat from 4500-redline. but i would think that at 18 pounds of boost, your numbers would be higher. oh wells, it might be a conservative tune, but at 18 pounds, you are no where near conservative
Modified by graphic at 7:33 PM 7/6/2005</TD></TR></TABLE>
Old Jul 6, 2005 | 01:20 PM
Sam1am26's Avatar
I'm using a turbonetics T3/To4b from an F-Max kit... I've been searching for a while now to find the housing sizes... If anyone knows please help me out... I hit full boost just under 4000 RPMs...
214.2 whp @ 7150 RPMs 194.9wtq @ 4400 RPMs 6 PSI w/boost leaks
Old Jul 6, 2005 | 05:16 PM
spoolinlude's Avatar
I live under a rock
Default Re: Kinda poll- what kind, size of turbo do you use in your preludes? (Sam1am26)
GT35R
.63 hot
70 a/r
No idea about boost yet.... car still ain't dun...
estimating 600ish at 25psi
Old Jul 7, 2005 | 02:00 PM
pentaq's Avatar
Default Re: Kinda poll- what kind, size of turbo do you use in your preludes? (spoolinlude)
bump! where are those turbo-guys?
Old Jul 7, 2005 | 02:37 PM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">GT35R
.63 hot
70 a/r
estimating 600ish at 25psi</TD></TR></TABLE>
same hear except i got .82 a/r.
old one was 60-1 .70 cold .82 hot side. started seeing boost at 2500 full boost of 19 psi just under 5k.
made 452 whp with crower intake cam and a stock exhaust cam choking it. this was one of my first turbo setups. strait h22
Old Jul 8, 2005 | 06:18 AM
pentaq's Avatar
Default Re: Kinda poll- what kind, size of turbo do you use in your preludes? (fastludeh22)
bump
Old Jul 8, 2005 | 09:12 AM
optikal_blitz's Avatar
bump, Blaast performance kits look like an amazing value!
Old Jul 8, 2005 | 09:20 AM
ChrisRicketts's Avatar
Precision T3 SC-61
.69 A/R Compressor,
.63 A/R exhaust
.76 trim
good to 680 hp
i made 266whp, 197wtq on a stock block on 7psi with this turbo......good spool up for a larger t3/t4.
the 60-1 my car was tuned on with the built block made 377whp, 333wtq on 20psi with a 2.25" dp.........i changed over to my SC-61 and a 2.5" dp without retuning.........4 months later the motor is now toast. next one will be a monster though!
Old Jul 10, 2005 | 05:58 PM
mikealike's Avatar
i have a stock H23A with 120.000 miles on it and i installed a 60-1hifi with .82 exhuast,, it made 302 hp and with 253 torque with a fmu and 2 fuel pumps and a 3in downpipe [/URL]
rx7_
Dec 14, 2009 07:11 AM
PhatBoy5015
Aug 22, 2006 11:17 AM
crj_lll
May 24, 2005 09:59 PM
bluedelsol
Jun 14, 2003 11:37 AM
99_SH
Feb 6, 2003 08:44 AM
