annoying fluctuating idle
Old Jul 5, 2005 | 12:38 AM
siregcivic's Avatar
Default annoying fluctuating idle
i replaced the motor in my girls car the other day with a 92 cx motor since hers was a dx with a cracked block and she only needs it to get from work and home...
ive tried everything to get a constant idle besides replacing sensors... i just used the ones off my motor ( d16z6 )
i unplugged the iac valve and it didnt do anything i took all the vacume lines off and sealed them still didnt help.
i tried swapping ecus went from a p06 to p05... that didnt do ****...
then i went from the p05 to my jdm p30 and it stopped fluctuating.. the only bad thing is that it idled at 1100..
but she cant keep my ecu and its pissing me off... does anybody know what it could be.. any help would be appreciated thanks in advance
Old Jul 5, 2005 | 02:28 AM
CivicSiRX's Avatar
give this a try. https://honda-tech.com/zerothread?id=1003988
Old Jul 5, 2005 | 07:16 PM
siregcivic's Avatar
Default Re: annoying fluctuating idle (siregcivic)
bump
i did all of that it still does it... when its cold and when its warm... ive switched the iacv with mine switched the throttlebody with mine and it still does it.
Old Jul 5, 2005 | 07:59 PM
miguel6632's Avatar
i bet is a vacum leak somewhere, just give it a quick check
Old Jul 5, 2005 | 10:52 PM
CivicSiRX's Avatar
ur not gettin any cels? check for vacum leaks, make sure u adjust the fitv, clean out the iacv, and ur tps is calibrated properly.
JdmJohnny210
28
Dec 31, 2012 12:08 AM
jayscivi
Dec 20, 2011 10:28 AM
924door
Aug 25, 2007 08:11 AM
I Hate Chassis Codes
12
Feb 10, 2005 01:48 PM
DX Hybridizer
Jun 7, 2003 01:59 PM
