Tachometer Question
Old Jul 4, 2005 | 02:13 PM
quincyrp's Avatar
Default Tachometer Question
I just got my new Tachometer in the mail the other day and my friend and i were trying to install it and we got everything working except for the nedel. neither of us knows where the tachometer terminal is and i would be very happy if someone could tell me where it is so i can fully install my tach. i drive a 1996 civic dx
Old Jul 4, 2005 | 02:21 PM
96-EJ6 B18C's Avatar
Default Re: Tachometer Question (quincyrp)
You can just tap off of the coil negitive wire for the rpm signal, that is the heavy blue wire that is coming out of the distributor.
Old Jul 4, 2005 | 02:56 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: Tachometer Question (96-EJ6 B18C)
Easiest way is to go under the hood of the car, look for a dead end single wire (blue) harness with a grey cap right by the driver side shock tower and clutch reservoir, tap there, it shouldn't be hard to find
Old Jul 4, 2005 | 02:58 PM
BlueIntegraBoy's Avatar
Remove your gauge cluster. There's an all blue wire running from one of the plugs. Tap off that wire for your RPM signal.
Old Jul 4, 2005 | 03:38 PM
neutron91's Avatar
Default Re: Tachometer Question (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">Easiest way is to go under the hood of the car, look for a dead end single wire (blue) harness with a grey cap right by the driver side shock tower and clutch reservoir, tap there, it shouldn't be hard to find</TD></TR></TABLE>
... easiest way and looks alot cleaner... you wont have an ugly wire running across the engine bay to the dizzy
jmall8691
May 11, 2011 07:17 PM
jareddx
Mar 4, 2010 06:59 AM
trevorjohn88ef
Feb 24, 2008 07:46 PM
97grnrs
Jan 11, 2006 07:32 PM
wood
Mar 26, 2005 02:49 PM
