sqeeking problem?
Old Jul 4, 2005 | 12:35 PM
upwind's Avatar
Default sqeeking problem?
I have a 2002 honda accord special edition and on the front right side of the vehicle there is a horrible squeeking noise. it happens when iam driving no matter what speed iam driving at and when i go in reverse,and when iam coming to a stop. is this the brakes rubbing on somting or the rotor rubbing on somting or lack of lubrication.
Modified by upwind at 2:40 PM 7/4/2005
Old Jul 4, 2005 | 01:45 PM
upwind's Avatar
Default Re: sqeeking problem? (upwind)
i took off the wheel but i dont see anything wrong.i had brought it to honda about 3-4 weeks ago and they said they didi a check up on it. i dont think they did anything to the brakes though.
Old Jul 4, 2005 | 01:53 PM
Confuc1ous's Avatar
check the shimms, i think thats what they are called. Sometimes they tend to get loose and can rub up against the rotor and create a squeeking. This has happened to me in another car of mine that wasnt a Honda, but its worth a look.
Old Jul 4, 2005 | 01:55 PM
upwind's Avatar
Default Re: (Confuc1ous)
thanks alot
Old Jul 4, 2005 | 02:05 PM
upwind's Avatar
can it be somthing else beacuse i didnt see that whne i was looking at the pads.
Old Jul 4, 2005 | 02:25 PM
P_Adams's Avatar
There are several sourses for suspension noises in Honda's
1) Dry / Worn Bushings
2) Dry / Word Ball Joint (s)
3) Bent / Misaligned Disc Rotor Shield
4) Glazed Brake Pads.
5) Worn Brake Pads, wear sensors rubbing rotor
1 & 2 Happen only when the susspension moves. You can make the noise by bouncing the car down/up.
3, 4 & 5 Happen only when the vehicle moves.
You're going to have to determine which.
P
Old Jul 4, 2005 | 06:23 PM
havalilsi's Avatar
Default Re: sqeeking problem? (P_Adams)
I have a similar sounding problem on the same wheel. The caliper spring is rubbing on the leading edge of the rotor. If you take off the wheel the rotor should be shiny where its rubbing. Nothing ever touches that part so it should not be shiny.
Old Jul 5, 2005 | 05:15 AM
deserthonda's Avatar
remove the inner brake pads and chk the wear bar ..at times pads wear uneven you can look at the outside pads and looks ok but the inner pads could worn,,
Jared Settle
Honda Accord (2013 - 2015)
Oct 16, 2017 01:28 PM
Kevin1540
Nov 18, 2013 12:50 PM
hondacc
Mar 12, 2010 12:17 PM
Aeka GSR
Sep 1, 2004 07:32 PM
icet
Jun 9, 2004 06:38 AM
