Swap into 99 EK
Old Jul 4, 2005 | 07:24 AM
shinbone's Avatar
Default Swap into 99 EK
I have 99Ek, and have 97 B19C5 (US Type-R), I have done all the wiring for the engine, but I noticed that 99Eks have different wiring loom, something with 0bd2b instead of Obd2a, can some one assist me with what I am doing wrong, I can turn the car and it will start for like 3 sec. and dies out.
Had the engine on 96 Ek, and I took the engine out to replace with 99ek body because the frame on the 96 ek was bad. So I had the engine running before hand, please help me with any ideas, thank you.
Old Jul 4, 2005 | 07:32 AM
Prod's Avatar
Default Re: Swap into 99 EK (shinbone)
no cel's ? if i had to guess with the information available maybe something with the wiring on the iacv plug...2 vs 3 wire
http://www.ff-squad.com/tech/w...8.jpg
http://www.ff-squad.com/tech/w...1.jpg
Old Jul 4, 2005 | 07:43 AM
Kwisatz Haderach's Avatar
Search, I guarantee someone has posted this before.
Old Jul 4, 2005 | 08:38 AM
moto1320's Avatar
On your first set up your OBD's matched, no sweat. Now you are going B to A. The easy way out is a 99 si harness with a adapter harness to your ECU of choice. I would recommend OBD1 P28 and an engine management program. Mild tuning on that engine will get you alot for a couple hundred bucks. Hondata S100 and a few shitty very used boltons netted 183 WHP on a recent Type-r swap. Best HP vs dollar you can do.
EK_HATCH509
Apr 4, 2012 03:08 AM
subliminaltrance
May 9, 2008 09:28 AM
jdmkevin
Jun 15, 2003 09:04 PM
