Engine shuts off, V-AFC shuts off, and oil light comes on
Old Jul 3, 2005 | 09:24 PM
Ri5e's Avatar
Default Engine shuts off, V-AFC shuts off, and oil light comes on
My friend was driving in his 90 CRX and it just suddenly shut off. Oil light comes on but the v-afc is off. Everything else works (music, lights, etc)
He took out the key the oil light goes off and it cranks but doesn't want to start.
What could be the problem?
Old Jul 3, 2005 | 10:00 PM
sohcvtec1995's Avatar
Default Re: Engine shuts off, V-AFC shuts off, and oil light comes on (TurboSmart)
dose the afc turn back on? or dose it stay off? also is there a cel? or just the oil light?
Old Jul 3, 2005 | 11:29 PM
PURPLETERROR aka BIGMATT's Avatar
alternator fuse, ecu fuse
Old Jul 4, 2005 | 10:20 AM
Ri5e's Avatar
Default Re: Engine shuts off, V-AFC shuts off, and oil light comes on (PURPLETERROR)
Ok, this morning he turned the key but the V-AFC doesn't work. Everything else works.
Checked all fuses and everything is good. Checked all of the wiring of the V-AFC to the ECU and they are all fine. Does the V-AFC have some sort of fuse inside?
Check Engine light, oil light, seat belt light, and all of the other lights are on
Old Jul 4, 2005 | 10:57 AM
NikoZai's Avatar
Still sounds like ECU fuse to me unless you're saying the car started this morning.
Check your wiring to that VAFC... Check continuity, voltage etc... Read up on how to troubleshoot electrical if you don't know how. http://www.the12volt.com
Old Jul 4, 2005 | 06:34 PM
Ri5e's Avatar
Default Re: Engine shuts off, V-AFC shuts off, and oil light comes on (NikoZai)
I was browsing around on another forum and another person had a similar problem because of a bad main fuel relay.
Old Jul 4, 2005 | 09:24 PM
if the AC is not turning on then the car wont star. since it is bypassing some sensors. The afc could be fried. i would unhook it and try running the car without it.
Dasani
Aug 8, 2005 09:03 AM
96gsrlmo
Apr 15, 2004 05:37 PM
Patch
Dec 10, 2003 04:09 PM
LODOSS
Dec 10, 2003 01:26 AM
00TurboEX
Aug 5, 2002 06:31 PM
