ECU code light on all the time
Old Dec 9, 2003 | 06:45 PM
LODOSS's Avatar
Default ECU code light on all the time
I am currently building my car for LS/V so I have a lot to do. My VAFC did not turn on today when i turn the ignition on. The ecu troubleshoot light is constantly on. what will cause this? Also i pulled the ECU backup fuse out. does anyone know if the ECU backup fuse is out the VAFC will still come on or not. I hope I did'nt break my VAFC. When i frist installed it it came on no problem and I really have check it since then and it has been a week and i've done a deck install and head swap so far but as of right now the car is not running.. also when i was testing I was using one of those battery chargers. maybe not enough voltage? any input would be greatly appreciate. I thought i broke my SAFC before but it turned out that the plug in there was loose. and i was so happy when it turned back on after i rewired it. I hope the same thign will happen here. thanks in advance!
Old Dec 9, 2003 | 08:55 PM
LODOSS's Avatar
Default Re: ECU code light on all the time (LODOSS)
bum,p
Old Dec 9, 2003 | 09:11 PM
LODOSS's Avatar
uu
Old Dec 10, 2003 | 01:26 AM
BlackThorN's Avatar
just a helpful suggestion. but if you seperate your sentances into seperate thoughts, it might help people figure out what you're asking
also spacing and punctuation are your friend
91-lsvtecsi
Feb 9, 2006 02:48 PM
z6CRXSi
Jun 7, 2005 12:41 PM
96gsrlmo
Apr 15, 2004 05:37 PM
thehondaguru
Aug 12, 2003 08:54 AM
tmg
Jun 24, 2002 06:17 PM
