Unable to set timing on Jdm b18?
Old Jul 3, 2005 | 11:11 AM
Stoich's Avatar
Default Unable to set timing on Jdm b18?
Hey guys I have been working on my car for the past 3 weeks trying to solve my bogging/stalling problem.
My question is that I had the timing light on the car and i cant seem to get the timing right no matter how far i turn the dizzy it wont come in to where its supposed to be.
Could a faulty Dizzy cause this type of problem?
Old Jul 3, 2005 | 11:13 AM
Stoich's Avatar
Default Re: Unable to set timing on Jdm b18? (Stoich)
Btw the car is running on a obd1 conversion with a chipped p28 ecu
If I have to replace the dizzy is this the right one?
http://www.distributorking.com...D44&0
Old Jul 3, 2005 | 11:15 AM
KayOs's Avatar
Warm up car properly to operating temperature.
Then make sure you are "jumping" the service connector that is located on the passenger side fender well and turn off all accessories devices in the car.
Old Jul 3, 2005 | 11:23 AM
Stoich's Avatar
Default Re: Unable to set timing on Jdm b18? (KayOs)
Thats the thing to even keep the car on you have to pump the gas to hold the idle so it wont stall out
everything else is off
To set the timing the service light connector has to hooked?
this is the one you use to see what codes you have correct?
Old Jul 3, 2005 | 11:27 AM
KayOs's Avatar
What chipped ECU are you running?
Service connector is the one you retrieve eror codes from. It does not have to be hooked but it does have to be "jumped". Just use both ends of a paper clip and insert into the connector to jump.
Old Jul 3, 2005 | 12:16 PM
Stoich's Avatar
a Neptune ecu
OK so i jump the connector like if i was gonna check for codes then set timing ?
Why does the connnector have to be jumped to set timing?
Old Jul 3, 2005 | 06:55 PM
Stoich's Avatar
Ordered a new dizzy
any other ideas?
Old Jul 4, 2005 | 10:32 AM
locash's Avatar
Who programmed this ecu for you?
Also, I would check to make sure that your cam timing is correct..
Old Jul 4, 2005 | 10:42 AM
Stoich's Avatar
Default Re: Unable to set timing on Jdm b18? (locash)
Jeff evans at Evans tuning .
So in order to adjust timing i have to jump the service wires like if i where going to pull codes ? After that adjust the timing to spec correct?
Old Jul 4, 2005 | 11:30 AM
Stoich's Avatar
Just checked cam timing its dead on .
What would a fualty dizzy cause the car to do?
Old Jul 4, 2005 | 12:12 PM
Stoich's Avatar
Well the car still has a **** idle and wont rev
Cam timing is dead on
Ignition timing is dead on
Ideas?
Old Jul 4, 2005 | 06:29 PM
Stoich's Avatar
dump bump
Old Jul 5, 2005 | 03:16 AM
Stoich's Avatar
The dizzy i got here in the Fs section has TD81 stamped on it
How do i tell if its OBD1 or obd2?
Old Jul 5, 2005 | 03:26 AM
Stoich's Avatar
distributor king shows this as a obd2 dizzy
When i got it on HT that **** told me it was a obd 1
this could explain my problem !
polishedturd
May 8, 2008 06:51 PM
jaydmtim
Sep 11, 2007 06:33 AM
slowcordreal
Mar 6, 2006 04:55 PM
the.hamburglar
Aug 8, 2005 01:12 PM
Nextelbuddy
Mar 30, 2004 10:09 AM
