OBD0-1 conversion , Ign. Timing Adj. Connector?
Old Jul 3, 2005 | 10:42 AM
Arvid's Avatar
Default OBD0-1 conversion , Ign. Timing Adj. Connector?
Iīm done with a OBD0-1 conversion on my 89 CRX. Everything is working correctly with no codes, however Iīm unable to find out where the Ign. Timing Adj. Connector is located on a OBD1 ECU. On the OBD0 ECU itīs located at pin B20 according to this link : http://www.hondaswap.com/forum...29360
Can anyone tell me where this is located on a OBD1 ECU ?
Old Jul 3, 2005 | 06:12 PM
curioso's Avatar
Default Re: OBD0-1 conversion , Ign. Timing Adj. Connector? (Arvid)
my man i got a dilemma do u by any chance have the instructions for ur obd0 to 0bd1 harness instructions cuz i lost mine and thats all i need to finisch my conversion i would appreciated if u can send me a copy of them thanks man
Old Jul 3, 2005 | 07:16 PM
Arvid's Avatar
Default Re: OBD0-1 conversion , Ign. Timing Adj. Connector? (curioso)
I donīt have the instructions , my conversion harness didnīt come with any. However if you use the ECU pinouts located here http://tech2.hybridgarage.com/..._obd1 and here http://www.hondaswap.com/forum...29360 you should have all the info you need.
As to my original question , I read some more in my helms manual and it seems to me that I should jump the connector that I use for checking codes to set the ignition timing. Is this correct ?
Old Jul 3, 2005 | 07:37 PM
curioso's Avatar
hope this helps man, http://www.hondaswap.com/forum...29360
link
let me know ifit did thanks for the info
zrickety
Jun 18, 2011 12:18 PM
Tensa_Zangetsu
23
Nov 23, 2008 08:09 PM
prionailurus
Mar 25, 2008 12:28 AM
k20oneday
Jun 4, 2007 07:54 AM
