1990 CRX miss....
Old Jul 3, 2005 | 08:50 AM
Skinflute22's Avatar
Default 1990 CRX miss....
well my mom just bought a 1990 crx hf with a d15b7 and mpfi... about 3000 rpms it misses bad. we've replaced the dizzy and the plugs and its still missing. any info or help will be greatly appreciated..
TIA
Old Jul 3, 2005 | 09:10 AM
Burlyirishdude's Avatar
Default Re: 1990 CRX miss.... (Skinflute22)
Nice name.....
Welcome to the HF club.......Check all the ignition parts. that's all i can think of.
Old Jul 3, 2005 | 09:19 AM
Dancing is Forbidden's Avatar
Default Re: 1990 CRX miss.... (Burlyirishdude)
what ecu is it running? The d15b7 is an OBD-1 DX engine.
Old Jul 3, 2005 | 09:28 AM
maybe its not the b7 i dono its a 90 hf like i said its my moms so i don't know a whole lot about it its a mpfi engine 1.5 liter and it has the si harness
Old Jul 3, 2005 | 09:44 AM
Default Re: (Skinflute22)
It should be a B8. Should be an 8v motor. With a fat egr on top on the left of the motor. What makes you think it's an SI harness?
Old Jul 3, 2005 | 09:54 AM
Default Re: (Burlyirishdude)
the B8 i know is from a 92-95 CX
Old Jul 3, 2005 | 11:20 AM
importslife's Avatar
Default Re: (ih8jdm)
it would be a D15B2 that is what came in the usdm hf and dx 89-91 check your injectors. also check the timming cam/crank and ign! try turning the dissy all the way to one side and rev it, if it dose miss try to turn it the other way. but if it takes care of the problem then you will know witch way to go on the cam
Old Jul 3, 2005 | 07:23 PM
i know its an si harness because the driver side firewall plug has 8 wires instead of 12 and its not a b2 its MPFI...it might be a d15b6
tanjulio
Apr 20, 2016 01:26 PM
93siturbo
Dec 13, 2008 12:04 PM
GSRinmyCRX
Oct 7, 2006 11:04 AM
Rocky's_CRX
32
Oct 16, 2005 05:04 PM
enochnich
16
Feb 15, 2005 03:05 PM
