Does anyone noe how to disable the antenna from extending up?
If you just don't want it to go up disconnect the power antenna wire in the back of your stereo. But you really should just go to that same wire and put a switch in between the antenna and the stereo. That way you will have full control over when it goes up and down. Its easy.
you need to find the remote wire that powers the ant .take a test light and put the test light to each wire and turn the radio on and off. the wire that turns the test light on and off is the winner clip that wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingJeff »</TD></TR><TR><TD CLASS="quote">s2000 antanae meng.</TD></TR></TABLE>
If you dont listen to your radio then you can just shave it bro, I believe there are some people on here that plug it up with a plug like the ones used when going wingless. Search and it might come up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CgiRLGO »</TD></TR><TR><TD CLASS="quote">you can pull the rear panel out and disconnect the power line running to it.</TD></TR></TABLE>
