will a open wastegate cause a turbo to overspool ???
hello everybody....
iv been told that if ill run with a open wastegate the turbo will probably overspool, is it correct?
best regards moshik galimidi
if anything, it would underspool
open wastegate will be alot effective than routing it back in the downpipe, well that was the case for RX-7s when i worked on them.
leave it open should not hurt anything, besides heat up the engine bay more.
