GREDDY BOOST GAUGE OWNERS - Quick/Stupid question
When you turn the ignition off where does the needle point too?? Mine goes to the center "0".
"pic is at idle"
I'm trying to figure out if this is the cause of my slow battery drainage woes.
Thanks,
"pic is at idle"
Thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JAMinCiViC »</TD></TR><TR><TD CLASS="quote">When you turn the ignition off where does the needle point too?? Mine goes to the center "0".
"pic is at idle"
Thanks,</TD></TR></TABLE>
Jordan, if your needle is pointing at zero(as in perfectly horizontal) That means you are still getting power to that guage. And that is why your battery is draining. Anand had the same exact problem. On my greddy guages, once I turn off the car, all of them go vertical (even the boost gauge). I think your problem is that you have your Orange wire(ignition wire) connected to a constant source, when it shouldn't be.
Khoi
"pic is at idle"
Khoi
What I did with my gauges is I wired them to the fuse box by your right knee. You can use a test light and find out which one is on turn key and which is not. That is what I use for my Apexi gauges and it works perfect!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR »</TD></TR><TR><TD CLASS="quote">What I did with my gauges is I wired them to the fuse box by your right knee. You can use a test light and find out which one is on turn key and which is not. That is what I use for my Apexi gauges and it works perfect!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver »</TD></TR><TR><TD CLASS="quote">
Khoi</TD></TR></TABLE>
werddd the test light will tell you which wires are constant and which ones are not.
It depends on if this is a mechanical or an electrical gauge.
My mechanical goes to zero, while my friends electrical pegs to one side or the other, I cant remember which.
Thanks guys... and KHOI!!! its electrical and Rubin hooked them up in the wrong spot with my EGT also!!
Wrong answer.
ALL the mechanical Greddy boost gauges stick at 0 when sthu off. The only ones that set to the lowest point when shut off are the electronic ones.
Wrong answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">
Wrong answer.
ALL the mechanical Greddy boost gauges stick at 0 when sthu off. The only ones that set to the lowest point when shut off are the electronic ones. </TD></TR></TABLE>
Yeah, but JAMinCiViC has an electrical guage
Wrong answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JAMinCiViC »</TD></TR><TR><TD CLASS="quote">Thanks guys... and KHOI!!! its electrical and Rubin hooked them up in the wrong spot with my EGT also!!
Yeah..I would assume so, since the same problem happened with Anand, and Anand's were installed by rubin as well
</TD></TR></TABLE>Yeah..I would assume so, since the same problem happened with Anand, and Anand's were installed by rubin as well
mortificationrock
Aug 22, 2008 11:13 PM
