vtec hits
5k...6k...?
You are all mistaken... Secondaries(Intake Air Bypass) are opened at exactly 5750 rpm.
And to answer the creator's question. Most people can hear vtec kick at 4400, but it isnt very noticeable without an intake or an exhaust. The IAB is much more noticeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless »</TD></TR><TR><TD CLASS="quote">4400? really? i have a short-ram on my car and i can't hear **** until about 5800 rpm...</TD></TR></TABLE>
me too, I can really hear it right around 5800 as well...
that noise isnt vtec, that noise is the butterflies opening.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnlimitedHonda5 »</TD></TR><TR><TD CLASS="quote">isant it like primary...then secondary.... then the butterflies.... and then vtec lobe oh well dohc vtec engines are a ''mystery'' lmao
No.. Its not a mystery at all, here is how it works for a stock b18c1...
idle-4399rpm: the car is running on the two small lobes of each camshaft...
4400-5750rpm: the vtec solenoid opens allowing oil pressure to travel through the rocker shafts, then through the rocker arms... forcing the two lower arms to pin together in to one solid block that includes the vtec(middle/bigger) arm on the camshafts... this has a distinct sound (tick-bwwwaaahhhhhh)
5750-redline: The ecu cuts the ground circuit to the solenoid that keeps vaccum suction holding the Intake Air Bypass valves closed, causing them to open... allowing a shorter path for the air from the throttle body to the head.
Fairly simple if you have an advanced mind... but also simple to any mind with the ability to learn.
One thing that I have never researched though... when you hit redline and the ecu "cuts the fuel" for short intervals, is it pausing the injector pulses... or is it holding back the spark and not actually cutting fuel (lean?)...
Post it up whoever knows!!! Thanks!
</TD></TR></TABLE>No.. Its not a mystery at all, here is how it works for a stock b18c1...
Kyles ej1
15
Dec 10, 2004 12:25 PM
Hapa88
Apr 22, 2004 09:20 AM
Unless I really concentrate that is
