vtec hits
Old Jul 2, 2005 | 09:38 PM
90hbvtec's Avatar
Default vtec hits
on a 95 gsr motor b18c when does vtec hits..can you hear it on a stock motor or does the motor needs to be mildy mod so u can hear it kick in..?..
Old Jul 2, 2005 | 09:54 PM
numbnuts22715's Avatar
i think it hits at like 4400, then secondaries open up at like 5k or something..
You should be able to hear the secondaries.. But you may not hear it hit at 4400.
Old Jul 2, 2005 | 09:57 PM
dc2vu's Avatar
4400 = vtec crossover
6000 = secondaries <---someone correct me if im wrong
pat.ter.rick's Avatar
Default Re: vtec hits (90hbvtec)
get an exhaust and you'll hear it...
Old Jul 2, 2005 | 09:58 PM
Default Re: (dc2vu)
secondarie kicks in around 5k
Old Jul 2, 2005 | 11:00 PM
2G0S0R1's Avatar
New User
Default Re: (dc2vu)
5k...6k...?
You are all mistaken... Secondaries(Intake Air Bypass) are opened at exactly 5750 rpm.
And to answer the creator's question. Most people can hear vtec kick at 4400, but it isnt very noticeable without an intake or an exhaust. The IAB is much more noticeable.
Old Jul 3, 2005 | 01:22 AM
phateless's Avatar
4400? really? i have a short-ram on my car and i can't hear **** until about 5800 rpm...
Old Jul 3, 2005 | 01:35 AM
ElementMotor's Avatar
Default Re: (phateless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless &raquo;</TD></TR><TR><TD CLASS="quote">4400? really? i have a short-ram on my car and i can't hear **** until about 5800 rpm...</TD></TR></TABLE>
me too, I can really hear it right around 5800 as well...
Old Jul 3, 2005 | 04:00 AM
Sifu's Avatar
Despite what every says about hearing it better when you have an intake or exhaust I can hardly hear it on mine Unless I really concentrate that is
Old Jul 3, 2005 | 09:53 AM
axi0m's Avatar
Default Re: (Sifu)
I hear mine at around 4800, then again my car is loud as ***** running an open exhaust. So yea.
Old Jul 3, 2005 | 10:12 AM
99exd16y8's Avatar
that noise isnt vtec, that noise is the butterflies opening.
Old Jul 3, 2005 | 10:26 AM
honda1982's Avatar
Mine open at 4800rpm. Get a V-AFC and mix it up a little. Oh yeah turbocharge it first, V-AFC are nothing unless you have Force Induction or a good built N/A.
Old Jul 3, 2005 | 12:33 PM
UnlimitedHonda5
Guest
Posts: n/a
Default Re: (honda1982)
isant it like primary...then secondary.... then the butterflies.... and then vtec lobe oh well dohc vtec engines are a ''mystery'' lmao
Old Jul 3, 2005 | 06:52 PM
2G0S0R1's Avatar
New User
Default Re: (UnlimitedHonda5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnlimitedHonda5 &raquo;</TD></TR><TR><TD CLASS="quote">isant it like primary...then secondary.... then the butterflies.... and then vtec lobe oh well dohc vtec engines are a ''mystery'' lmao </TD></TR></TABLE>
No.. Its not a mystery at all, here is how it works for a stock b18c1...
idle-4399rpm: the car is running on the two small lobes of each camshaft...
4400-5750rpm: the vtec solenoid opens allowing oil pressure to travel through the rocker shafts, then through the rocker arms... forcing the two lower arms to pin together in to one solid block that includes the vtec(middle/bigger) arm on the camshafts... this has a distinct sound (tick-bwwwaaahhhhhh)
5750-redline: The ecu cuts the ground circuit to the solenoid that keeps vaccum suction holding the Intake Air Bypass valves closed, causing them to open... allowing a shorter path for the air from the throttle body to the head.
Fairly simple if you have an advanced mind... but also simple to any mind with the ability to learn.
One thing that I have never researched though... when you hit redline and the ecu "cuts the fuel" for short intervals, is it pausing the injector pulses... or is it holding back the spark and not actually cutting fuel (lean?)...
Post it up whoever knows!!! Thanks!
Old Jul 3, 2005 | 06:53 PM
90hbvtec's Avatar
thanks guys..know i got an idea when it hits..
Old Jul 3, 2005 | 10:33 PM
dc2vu's Avatar
good clearin that up 2G0S0R1
lilpastrana
Sep 27, 2006 01:09 PM
J's GS-R
Feb 21, 2006 09:13 PM
veilsides2000
Jul 20, 2005 08:55 PM
Kyles ej1
15
Dec 10, 2004 12:25 PM
Hapa88
Apr 22, 2004 09:20 AM
