95 coupe WINDOW problem
Old Jul 2, 2005 | 09:29 PM
iLUVmyACCORD's Avatar
Default 95 coupe WINDOW problem
so uhh.. my window always made a noise when it opened and closed.. like a smll cracking noise and it would go up/down slower than the passenger side..
then last night.. i closed the door and i heard a loud crack..and the window doesnt work anymore .. it started dropping but i pulled it back up.... so what is broken? expansive fix? let me know... something i can do? just open the intereior part of door and check it out?
Old Jul 2, 2005 | 09:56 PM
NAiL05's Avatar
Default Re: 95 coupe WINDOW problem (Negronese)
Pull off your door panel then check the clip deals that go on your window and see if they cracked on you.
Old Jul 2, 2005 | 10:13 PM
deserthonda's Avatar
most likely it is your window regulator that got damaged
Old Jul 2, 2005 | 11:28 PM
could i fix this myself? im pretty much a hands on person... installing things myself.. this sucks..
Old Jul 3, 2005 | 09:29 AM
Beach Accord's Avatar
window regulator most likely....
need to take off the door panel and then the vapor barrier.... a couple 10mm bolts and maneuver it out of the hole.... put the new one in reverse of removal.
Old Jul 3, 2005 | 11:11 AM
i could buy new ones at? back at the honda dealership or autozone/ napa might carry it?
edit: how many screws hold the panel on? automatic windows.. ex
Old Jul 3, 2005 | 09:29 PM
momstaxi's Avatar
Default Re: (Negronese)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Negronese &raquo;</TD></TR><TR><TD CLASS="quote">i could buy new ones at? back at the honda dealership or autozone/ napa might carry it?
edit: how many screws hold the panel on? automatic windows.. ex </TD></TR></TABLE>
your best be would be a junkyard, as lx,ex,se came with power window you would be able to source a replacement out of any of those models...
take the door handle off first then take a flat head screw driver and from the bottom pop the clips out all the way around the panel... then slide it up and off...dont forget to unplug the courtesy lights when removing and the window switches...
Old Jul 3, 2005 | 10:02 PM
NAiL05's Avatar
i had to replace my driver side regulator for my 92. At advance they quoted me 115 or something like that for teh whole unit.
Old Jul 4, 2005 | 09:25 AM
CD7power's Avatar
Default Re: (NAiL05)
i had the same exact problem. i just picked one up on ebay for $85 shipped.
eric8876
Sep 13, 2004 05:36 AM
GeorgeY
Mar 28, 2003 12:23 PM
Phoenix Yellow R
Jan 17, 2003 05:24 AM
NuclearB18B
Jun 6, 2002 11:11 PM
RATEDR
May 23, 2002 06:39 AM
