always getting power
my freinds and i recently did battery relocations on our cars and we are all having the same problem...
with the car off/key out- for example we press the button for the air to point down to the ground it will light up. if we turn on the air it wont turn on but standing from the engine bay you can hear it going for some reason??
when you relocated the battery, all you did was ground the battery to the frame in the back and run a large battery cable from the +terminal to the front where it would have connected to the battery before, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drussell4801 »</TD></TR><TR><TD CLASS="quote">when you relocated the battery, all you did was ground the battery to the frame in the back and run a large battery cable from the +terminal to the front where it would have connected to the battery before, right?</TD></TR></TABLE>
yeah i thought that was the only way it could be done
