Gasket between mani and turbo?
Old Jul 2, 2005 | 12:59 PM
Mario.'s Avatar
Default Gasket between mani and turbo?
On the DRAG kits.. specifically b18b Integra application is there a gasket that goes between the turbo and the manifold? Buddy's leaking real bad from there.
Old Jul 2, 2005 | 01:03 PM
Muckman's Avatar
Moderator in Chief
Default Re: Gasket between mani and turbo? (Mario.)
try it without the gasket.
Old Jul 2, 2005 | 01:16 PM
Mario.'s Avatar
Default Re: Gasket between mani and turbo? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">try it without the gasket.</TD></TR></TABLE>
There is no gasket there now and it's leaking... that's why I am asking if there is supposed to be a gasket.
Old Jul 2, 2005 | 01:25 PM
93cicvicls's Avatar
there is a gasket that goes there, im pretty sure of it.If you dont have 1 try and find 1 that has the same bolt patter and just dremmal the inside to fit.I didnt have a gasket and when i had my o2 housing looked at guy said it would lose power from it and threw one he made from another turbo in.Also make sure you bolts or what ever you holding that section together is tight and has lock washers/lock tite or they will always get hot and get loose and can cause some real problems
Old Jul 2, 2005 | 01:40 PM
jDMJeRk's Avatar
wtf muck? LoL why would you do this?
-Nick
Old Jul 2, 2005 | 04:58 PM
SHystrdyGSRtdy's Avatar
Default Re: Gasket between mani and turbo? (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">wtf muck? LoL why would you do this?
-Nick</TD></TR></TABLE>
some people run fine without gaskets
Old Jul 2, 2005 | 07:21 PM
notoriousB's Avatar
Default Re: Gasket between mani and turbo? (SHystrdyGSRtdy)
here you go:
http://www.atpturbo.com/Mercha...e=GSK
Old Jul 2, 2005 | 07:41 PM
Muckman's Avatar
Moderator in Chief
Ive never run a gasket in my car or any of my friends turbo cars. Never seen any of them leak... *shrugs*
Old Jul 2, 2005 | 08:23 PM
kabaroo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Ive never run a gasket in my car or any of my friends turbo cars. Never seen any of them leak... *shrugs*</TD></TR></TABLE>
assuming that all the flanges are prefectly flat.
Old Jul 3, 2005 | 12:06 AM
AspectIndustries's Avatar
Old Jul 3, 2005 | 06:48 AM
DragSource's Avatar
Gasketless w/ copper spray.
If it doesn't seal, as said above - your flanges aren't completely flat, hopefully not warped to the point that a gasket won't work.
If they are warped - machine shop - 5 minutes, back in action.
Old Jul 3, 2005 | 05:20 PM
jDMJeRk's Avatar
Thats interesting... I wouldnt think it would make a good seal.
I guess go gasketless if it works!
Old Jul 3, 2005 | 07:13 PM
y7turbo's Avatar
copper rtv works awesome .. i use that when i dont have gaskets.. if i do have gaskets i spray them with the copper spray.. works like a champ.
Old Jul 3, 2005 | 07:17 PM
dennis's Avatar
no gasket here, no problems. I have seen a gasket blow out on the dyno though.
actionfigure
Jan 7, 2007 07:06 AM
95dc2teg
Jul 17, 2006 01:26 PM
O16581724 5 2 5
May 28, 2006 12:35 AM
dester223
Dec 16, 2005 08:26 PM
b18-c-rx
May 18, 2005 07:10 AM
