help with code 9 and code 22
Old Jul 2, 2005 | 12:54 PM
boostedlude01's Avatar
Default help with code 9 and code 22
just installed a hondata with a p28 ecu. i am running on a basemap. i am throwing code 9 and 22. code 9 is a cylinder sensor and code 22 is vtec pressure valve. any help with describing the codes and/or fixing the problems, would help. thanks
Old Jul 2, 2005 | 01:34 PM
britishlude's Avatar
Default Re: help with code 9 and code 22 (boostedlude01)
09 Cylinder Position sensor = Open or short in CYP sensor circuit, defective CYP sensor.
22 VTEC Oil Pressure Switch =
Open or short in VTEC OPS circuit, defective VTEC pressure switch
There isn't much else to check other than the wiring to the sensors for faults / shorts, other than that it's as matter of replacing defective sensors.
Assuming all the contacts in the ECU are firm and sound.
Old Jul 2, 2005 | 02:39 PM
Default Re: help with code 9 and code 22 (britishlude)
thanks, open to more suggestions
Old Jul 2, 2005 | 03:45 PM
bad-monkey's Avatar
cyp is in the distributor. the helms manual has a process for troubleshooting a 9.
jdmkid808
19
Apr 9, 2013 12:06 AM
ach2291
Feb 10, 2013 09:07 AM
brandynEG
Jun 28, 2012 06:23 PM
jdmasfuk
Aug 2, 2009 07:46 AM
