1999 civic cel code
1999 civic cel code
im trying to help out a friend of mine with his car because the car boggs sometimes..
he has a d16y8 stock motor with a p28 chipped (unknown specs)
i did a cel code and the codes are
13 = atmospheric pressure sensor
22 = vtec pressure valve (on his vtec solenoid that green sensor broke off so the code 22 is throwing but im not really sure if im correct)
41 = primary oxygen sensor heater.
for the code 41 im not really sure if the person who chipped the ecu disable this code but i have couple o2 sensor so i might try it out
if anybody has an info of getting rid off this cel code please help me out. thanks in advance!!
Re: 1999 civic cel code
why is he running a chipped ECU with a stock motor ? try and check the codes again with a virgin ecu(non-chipped) and see what you get
he bought the car that way.. also the car was converted to 5spd and the motor that he has on the car right now is not the original. I will try to use my obd2b ex 5spd ecu when i have time and try see if anything change.
window
so it's an OBD2 engine with and jumper to OBD1. So AFAIK you'r ex ECU should be the correct one as the ex(obd2) came with a Y8. just remove the jumper
okay i got the 13 and 22 cel out of the way with my ex 5spd ecu and 41 still a problem which is the o2 sensor.. new problem is that while the car was on the cel keep flashing then when we drove off the cel kept it steady.. now that's trippy.. is there any wire or ground that could cause this problem??? btw the car runs a little bit better..
well, that was a big crack on the vtec solenoid where the green plug was.. could that be causing the cel to flash?? and its now running with my old ecu which was ex 5spd obd2b
before i connected the ecu the battery was already disconnected.. we was fixing other problem which was the leak from the vtec solenoid and the green plug from the vtec.. thats why code 22 was throwing.. for code 13 i think the old ecu was messed up.. i did couple research on how to get rid of it.. they were saying that it was from the ecu. now before we start the car.. i did the cel code again and code 41 was the only code that i could get.. 13 and 22 is gone with the obd2 ecu.. and with the new problem the cel keep flashing when the car is in complete stop, but when we drove off the cel would be steady
Geis
12-17-2015 11:20 AM
Civic2Fast
02-11-2003 07:19 PM
