Car wont start?
Gotta start w/the basics: compression, fuel and spark. The usual suspects are the PGM-FI main relay under the driver's side dash or the ignition control module (aka 'ignitor') found in the distributor. Good luck.
yea i waited for about 2 hours then came back and turned my Key and waited a min the check engine lite went off then it started right up i guess its just wasn't gettin fuel, I seen in another post where they had the same prob. on a hot day went to start his car and wouldn't start then came back a lil later and it started.
Guest
Posts: n/a
Yeah ive had that prob on my old hatch a while back, so i changed out the igniter, or ignition coil some call, and that still din't work...lol. Turns out i got another used distributor from a bud and put it on with the better coil i was usin and started up fine.
boostedpleasure
13
Oct 12, 2006 09:10 AM
