OBD2 SOHC distributer connecting to an OBD2 LS motor
Old Jul 1, 2005 | 04:44 PM
jdmcivic1999's Avatar
Default OBD2 SOHC distributer connecting to an OBD2 LS motor
im swapping an ls motor into my 99 civic, i have to use my sohc wiring harness to run the motor but i came across a problem. i have an LS dizzy but the plug wont fit on the sohc wiring harness? im thinking about splicing the connecter to a sohc plug but there are 9 wires on the LS dizzy plug and only 8 on the sohc dizzy plug? if i am to splice them what do i do about the 9th wire? its an extra solid blue wire, anyone no where i goes or what it does? everything is OBD2 on the car. what would happen if i were to just swap the whole harness out of the LS dizzy and replace it with a sohc harness??
Old Jul 1, 2005 | 05:06 PM
slomofo's Avatar
GDD Member
I think the solid blue wire is the tach lead.
Old Jul 1, 2005 | 06:04 PM
Default Re: (slomofo)
ok so if thats the tach wire, can i run that wire straight to the tach?
PhrequenC
Aug 10, 2008 11:06 AM
PhrequenC
Aug 5, 2008 11:15 AM
Tippyman
13
Apr 11, 2006 09:05 AM
jdmcivic1999
Jun 27, 2005 06:56 PM
