leather GSR front & rear seats into a 93 DX hatch.
Old Jul 1, 2005 | 09:33 AM
Squallie's Avatar
Default leather GSR front & rear seats into a 93 DX hatch.
i was wondering what id have to do to make the front and rear GSR seats fit into a hatch. i think on the fronts i have to switch the seat rails or can i just bolt them in? but on the rear do i bolt them in or what? im not to sure about that. any help would be great!
Old Jul 1, 2005 | 09:52 AM
Chilly61383's Avatar
Default Re: leather GSR front & rear seats into a 93 DX hatch. (Squallie)
Its all direct bolt-in. The rear you might have a small problem with the hooks. But the front drop right in.
Old Jul 1, 2005 | 09:56 AM
Squallie's Avatar
Default Re: leather GSR front & rear seats into a 93 DX hatch. (Chilly61383)
so on the front i just unbolt the driver and passenger seats and then bolt up the GSR in the factory spot? sounds easy and i hope it is. but gimme more info about the rear seats, like what i may need to remove or whatever . anybody else feel free to put in your opinions or advice that you learned if you did the swap!
Old Jul 1, 2005 | 09:57 AM
futurefastguy's Avatar
the fronts will be a direct bolt on. but the back ones won't fit. the hooks won't match up, there will also be a inch gap all around the seat. i think the 4 door gsr seat might fit into a eg hatch. im not sure
Old Jul 1, 2005 | 10:22 AM
Squallie's Avatar
Default Re: leather GSR front & rear seats into a 93 DX hatch. (futurefastguy)
yea the seats are comming from a four door if im not mistaken, i should of listed that earlier, so if they are from the 4dr then would it be a direct bolt up?
Old Jul 1, 2005 | 12:35 PM
Squallie's Avatar
ttt
Old Jul 1, 2005 | 05:45 PM
boricua_SSL13's Avatar
yeh the front 2 bolt up directly and the rear lower section has a big gap and hook doesnt match where the 10mm bolt goes...just use a civic bottom section and integra top sections on the rear and it will be perfect...i have gsr seats in my hatch
Old Jul 1, 2005 | 06:57 PM
H.A.R.T B18C1EG6's Avatar
Default Re: leather GSR front & rear seats into a 93 DX hatch. (boricua_SSL13)
yeah the fronts will fit perfectly. But the rears will wiggle a bit because i think the bottom tabs dont lock on eg's. Mine are steady unless you touch em.
Old Jul 2, 2005 | 04:29 PM
Slamaccord's Avatar
Default Re: leather GSR front & rear seats into a 93 DX hatch. (H.A.R.T B18C1EG6)
Two front bolt up no prob like everyone else said. 4 door bottom piece with 2 door integra top piece ownzzzz yooo
I'll post a pic later.
Old Jul 2, 2005 | 05:22 PM
98b18black's Avatar
Default Re: leather GSR front & rear seats into a 93 DX hatch. (Slamaccord)
You don't have a car....Why are you asking?....Just Wondering...
hondateg10
Feb 13, 2008 10:19 AM
grizzy225
11
Oct 10, 2007 06:15 PM
O RLY
17
Jun 19, 2006 08:48 PM
s.patel
Sep 3, 2004 02:52 PM
whatVTEC
10
May 4, 2003 06:03 PM
