temp gauge overheating
I have a stock 92 civic ex. The temp gauge keeps going to hot but not over heating. Just replace themostat, didnt fix. I can rev up the engine and the temp gauge goes down. Any help please??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 »</TD></TR><TR><TD CLASS="quote">you might have a little air in your block, try letting your car warm up with the radiator car off and your heat on high.</TD></TR></TABLE>
does your rad. fan turn on? if not, it could be dued to faulty fan sensor located on thermostat housing..If it is then rebleed your cooling system and make sure you have the right mixture...
Also check your fuses...
Worked for my brother's DA.
There should be a bleeder screw by the top radiator hose(im not sure on D series). You can fill the radiator to the highest it can go then crack the bleeder screw till you get a constant flow of coolant. That might take all the air out.
brandond
Nov 6, 2005 02:59 PM
