CTR Cam Dyno's
Old Jun 30, 2005 | 08:32 PM
BLK99VTECR's Avatar
Default CTR Cam Dyno's
Does anyone know where i can get some graphs of CTR cam dynoes on B16s and B18gsr?
Old Jun 30, 2005 | 10:17 PM
eXcelonTypeR's Avatar
Default Re: CTR Cam Dyno's (BLK99VTECR)
http://www.importreview.com tons of graphs on there, its run by the same guy that does ImportBuilders.com
Old Jul 5, 2005 | 03:34 PM
BLK99VTECR's Avatar
still need some dynos?
Old Jul 5, 2005 | 04:48 PM
Default Re: (BLK99VTECR)
What dyno graphs...theres many on that site that used CTR cams, just have too look around for em, mostly in the section that says Dyno charts. Or you could search the forums here, just type in CTR cams and pick archived, you'll get about 897 results
Old Jul 5, 2005 | 08:13 PM
BLK99VTECR's Avatar
Default Re: (eXcelonTypeR)
looking for CTR cam dynos in GSRs motors
Old Jul 5, 2005 | 08:21 PM
search dude
Old Jul 13, 2005 | 02:00 AM
oldskool teggy's Avatar
https://honda-tech.com/zerothread?id=1247844
its an lsvtec.. but its got ctr cams, stock b16 head, and 11.5 CR bottom end
Old Jul 13, 2005 | 07:13 AM
SkoundrelUSA's Avatar
cute little bastard
That link works perfect fool
eXcelonTypeR
Old Jul 13, 2005 | 08:11 AM
Downey's Avatar
BLUE LINE: JDM GSR (stock p72 block & p72 head, gsr manifold, 5zigen 4-2-1 header, test pipe, rsr exhaust, gsr cams)
RED LINE : JDM GSR (stock p72 block & pr3 type r header, 5zigen 4-2-1 header, 2.5" high flow cat, rsr exhaust, ctr cams)
GREEN LINE : US B17A (iceman intake, jdm 4-2-1 2" collector header, 2.5" highflow cat, rsr exhaust, ctr cams)
Old Jul 13, 2005 | 03:47 PM
BLK99VTECR's Avatar
Default Re: CTR Cam Dyno's (Downey)
the numbers on the graph show 2 different results. the detail boxs shows one and then the plot shows another. I will assume the plot is the real numbers
Old Jul 13, 2005 | 04:05 PM
Combustion Contraption's Avatar
They show the same numbers, but the numbers there showing directly next to the hp and tq lines arent the peak numbers, which are stated in the top right corner of the graph. Look at it, you can see where the numbers are, the lines arent even done climbing yet.
Old Jul 14, 2005 | 05:20 PM
BLK99VTECR's Avatar
Default Re: (LsVtec92Hatch)
o ok
allinone07860
Dec 7, 2005 06:13 PM
mosteceg
Mar 24, 2005 11:05 AM
hitvtecgetloud09
Apr 16, 2004 12:18 AM
B18C2_sedan
Apr 18, 2003 03:33 AM
NCHATCH
Feb 28, 2003 09:57 PM
