Best turbo set up?? need help...
For you...What is the best turbo setup on B18C5 for arround 400hp...??
Cr for pistons?? (I think JE 9:1)
Rods?? (I think Eagle H-beam)
Turbo?? ( T3/T4s)
Psi?? ( arround 15 psi)
Wastegate diam? (40mm)
Turbo's Header? ( I do know..)
Injectors? ( maybe 750 cc...)
Camshafts?? ( need to change or not?)
Electronic??? (...hondata i think...)
crankshaft?? ( need to change or not??)
clutch?? (...good question...lol)
You can complete the list...
All positives suggestions is good for me...
Turbo?? ( T3/T4s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude300hp »</TD></TR><TR><TD CLASS="quote">For you...What is the best turbo setup on B18C5 for arround 400hp...??
Turbo?? ( T3/T4s)
I would also try the FI forum if you haven't.
JE 9:1 pistons, Any rods, An efficient header (Full-race, other). Balance the stock crank while it's open. Stock cams. Hondata works. Action 2MD clutch is rockin' for me, with a Fidanza flywheel. GT30R might be a good choice for a turbo. 550cc injectors have been fine for me up to 320 WHP, 750 is probably a good idea. GM 5-bar MAP sensor.
I'd stay away from sleeves/block guard/etc. Not worth it. Dudes have made 500+ WHP on stock sleeves. 350 or 375 might be safer, and anything more is useless unless you're a drag racer and have slicks
https://honda-tech.com/zerothread?id=1267344
Anyhow, good luck, search and search and search in the FI forum. In those million posts over the last 5 years, your question has been answered before.
Turbo?? ( T3/T4s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude300hp »</TD></TR><TR><TD CLASS="quote">All positives suggestions is good for me...
Turbo's are expensive and problematic. Very over rated. Not to be a dick, but if your asking random strangers on the internet to 'complete your shopping list', then it may be best for you to research the parts in question
just my worthless .02 on the matter.
.just my worthless .02 on the matter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude300hp »</TD></TR><TR><TD CLASS="quote">For you...What is the best turbo setup on B18C5 for arround 400hp...??</TD></TR></TABLE>
Trade it in on a Z06.
Drinker
