sooooo confused need some advice
Old Jun 30, 2005 | 03:11 PM
Redline it.'s Avatar
Default sooooo confused need some advice
im tryin to install power locks, i got the relays and aftermarket actuators. i was tryin to take off the dx door panel......it was comming off except for one part, the window handle thing that moves the windows up and down. the fukin door panel wont come off unless i take that handle thing off. its in the way
Old Jun 30, 2005 | 03:15 PM
DFW's Avatar
DFW
Default Re: sooooo confused need some advice (FRISCOthaCITYdatDONTsleep)
Long *** screen name...bump for you
Old Jun 30, 2005 | 03:16 PM
neutron91's Avatar
yes you have to take the window crank off... if you lightly pry out on it a bit with a screwdriver you will see a brass clip... just turn the crank until you can see the 2 ends where it clips... once you see that just push on one of them with a screwdriver and it should pop out... then just pull the handle off
Old Jun 30, 2005 | 03:23 PM
Default Re: sooooo confused need some advice (neutron91)
Old Jun 30, 2005 | 04:37 PM
eg6coupe's Avatar
dont loose the clip it sux i know but thats how you do it like neutron91 said
Old Jun 30, 2005 | 04:39 PM
96CivicBoostCoupe's Avatar
Default Re: sooooo confused need some advice (eg6coupe)
get a window crank removal tool 3 bucks at any automotive store
Old Jul 2, 2005 | 08:31 AM
Default Re: sooooo confused need some advice (96CivicBoostCoupe)
B18cHatch06
Jul 18, 2007 08:36 PM
ddclutch
Honda Fit
Jul 4, 2006 11:06 PM
okman16
26
Nov 9, 2003 12:48 PM
Mentat Ghola
Jan 11, 2003 04:47 PM
IdotheSHOCKER
Aug 15, 2002 03:43 PM
