TIAL 38mm WG size difference between big and small springs?
Old Jun 30, 2005 | 12:36 PM
BlueShadow's Avatar
Default TIAL 38mm WG size difference between big and small springs?
Hi guys,
I have two TIAL WG springs which I am trying to sell. How big in diameter are the small springs? I think the spring I have is the big green one, but I need to be sure before I sell it. What is the diameter of the big and small springs?
TIA
Old Jun 30, 2005 | 12:40 PM
dustin's Avatar
Default Re: TIAL 38mm WG size difference between big and small springs? (BlueShadow)
the small ones are about 1.8" in diameter, and the large ones are about 2.25" in diameter IIRC.
Old Jun 30, 2005 | 07:26 PM
BlueShadow's Avatar
Default Re: TIAL 38mm WG size difference between big and small springs? (dustin)
cool, thanks dood
From the looks of it I have a large green spring. Just curious, are the small ones meant to go into the large ones to increase your overall spring rating?
Old Jun 30, 2005 | 08:12 PM
skunkwhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">cool, thanks dood
From the looks of it I have a large green spring. Just curious, are the small ones meant to go into the large ones to increase your overall spring rating? </TD></TR></TABLE>
yeah you an mix and match to get the pressure you need
Old Jun 30, 2005 | 08:16 PM
BlueShadow's Avatar
Default Re: TIAL 38mm WG size difference between big and small springs? (skunkwhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkwhat &raquo;</TD></TR><TR><TD CLASS="quote">yeah you an mix and match to get the pressure you need</TD></TR></TABLE>
thanks
I just wanted to make sure, cause my 0.4 bar which I got from importparts is the same size as the spring which I got from Revhard, which is the spring I'm unsure of. According to TIAL's color code, the large green spring I got from Revhard is the 7.25 psi or 0.5 bar spring.
Old Jun 30, 2005 | 08:20 PM
dustin's Avatar
bar-psi-color
0.5-7.25-Small Green
0.9-13.05-Big Green
from tial's site....
Old Jun 30, 2005 | 08:29 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">bar-psi-color
0.9-13.05-Big Green
from tial's site....</TD></TR></TABLE>
whoops, it looks like I have the small springs then. I'll just bust out my tape measure and compare the sizes of both my springs. I know for a fact that importparts sent me the 0.4 bar spring.
DOHC_16v
Aug 3, 2011 01:35 PM
frostwhite_92
Suspension & Brakes
12
Mar 1, 2006 09:40 AM
integratuner94
Mar 24, 2005 04:05 PM
J337_UNIT
Mar 18, 2004 02:02 PM
