Precision WG spring in TiAL WG?
Old Aug 3, 2011 | 01:16 AM
DOHC_16v's Avatar
Default Precision WG spring in TiAL WG?
I have to change the spring in a TiAL WG. Got a bag full of precision PW39 springs, 2x all 5 sizes. Just wondering if the springs are interchangeable from the PW39 to TiAL WG38.
I have a few TiAL springs too but none are the right size and I'd rather not bother to look for one.
Anyone tried it? Seems like it should work, the only thing I could think of is that the boost could be a bit off +/- 1-2psi which is not a big issue.
Old Aug 3, 2011 | 07:53 AM
Turbo-LS's Avatar
Default Re: Precision WG spring in TiAL WG?
IDK if this helps but ive use turbosmart wg springs in my tial wg and worked out ok
Old Aug 3, 2011 | 09:11 AM
SovXietday's Avatar
Do the Precision springs have a similar height and width to the TiAL ones?
If yes, in the end it's just a spring. Pop it in and have fun.
Old Aug 3, 2011 | 12:29 PM
DOHC_16v's Avatar
The bigger ones that I want to use have a similar width to the TiAL ones but the're taller. I'm gonna try it and see what happens.
Old Aug 3, 2011 | 01:35 PM
SovXietday's Avatar
You may run into two issues with them being taller.
1) It will probably result in a higher spring pressure.
2) The spring may bottom out before the gate is all the way open.
Never know till you try though.
damndan23
Aug 16, 2009 12:11 PM
chunkybs
Apr 13, 2008 08:17 AM
akira712
Aug 8, 2006 09:46 PM
DSRxSALSA
Dec 19, 2005 06:41 PM
hotasscivic
May 23, 2004 09:24 PM
