Suspension & Brakes Theory, alignment, spring rates....
type r and gsr lower control arms
Old Jun 30, 2005 | 11:50 AM
RabbittZ's Avatar
Default type r and gsr lower control arms
are these interchangeable. ive looked, but couldnt find anything. does anyone know if i can switch these two?? for example, type r brake set up with gsr REAR lower control arms????
Old Jun 30, 2005 | 12:37 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: type r and gsr lower control arms (RabbittZ)
If you want to retain your existing LCAs for a brake swap or something like that, then yes you will be fine.
If you are trying to replace your GSR LCAs with Type R LCAs (or vice versa), you will have to use the matching shocks as well. The only difference is the way the rear shocks attach. Other than that mechanical difference, they are geometrically identical...
What is it exactly that you are trying to accomplish (and on what car)???
Old Jun 30, 2005 | 07:39 PM
RabbittZ's Avatar
alrighty, thanks. thats what i thought.
just to fill ya in. its type r brakes with gsr control arms, so that i can keep my current suspention. thanks again!
Old Jun 30, 2005 | 09:21 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (RabbittZ)
It will work perfectly...
Old Jul 1, 2005 | 04:31 PM
RabbittZ's Avatar
thanks 94eg! take care man!
Old Jul 1, 2005 | 09:27 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
byran bryan byran u shoul dknow this mannnn
Old Jul 2, 2005 | 01:50 PM
RabbittZ's Avatar
lol.. i do know ... ( and its brIan sucka!! )
whats up with this meet your planing???
Old Jul 4, 2005 | 02:50 PM
FlatBrokeHatch's Avatar
I read in a few other threads that they were different lengths...but noone seemed to know for sure. Arguing about EG/GSR/ITR interchangeability. Are they all the same lengths?
Old Jul 4, 2005 | 02:56 PM
RabbittZ's Avatar
im guessing yes. if you can put gsr's on a eg and then put type r's on a gsr, they should all be interchangeable?
Old Jul 5, 2005 | 07:11 AM
94eg!'s Avatar
#1 Super Guy
Loved
They are ALL interchangable. If you use Type R rear LCAs, you must use Type R style rear shocks (thats the only difference). Only the 96-00 civics have different length rear LCAs (they are longer and therefor not interchangable).
Old Jul 5, 2005 | 11:32 AM
Default Re: (94eg!)
Thank you for clearing that up.
kcjohnnyboy
Oct 1, 2003 06:53 AM
civh
Aug 13, 2002 10:21 AM
