D16 Swap in CRX... to much crank case pressure help!!!
Old Jun 30, 2005 | 09:14 AM
Adam_11's Avatar
Default D16 Swap in CRX... to much crank case pressure help!!!
Ok so my friend did a D16 swap in his CRX and its fully built and everything the only prob is he thinks there is too much crank case pressure cause there is oil leakin out of the distributor
Old Jun 30, 2005 | 10:35 AM
C-RICKS's Avatar
Default Re: D16 Swap in CRX... to much crank case pressure help!!! (Adam_11)
did he change the "O" ring?
And was it the correct one?
Old Jun 30, 2005 | 12:00 PM
bagpipe goatee's Avatar
if the pcv is good, and it doesn't have that outlet on the valve cover plugged, theres not too much crankcase pressure. change the o ring, plus i hear that they get sloppy when they're dying.
Old Jul 1, 2005 | 07:57 AM
Adam_11's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">if the pcv is good, and it doesn't have that outlet on the valve cover plugged, theres not too much crankcase pressure.</TD></TR></TABLE>
he just changed all the pcv stuff, wich "O" ring are you guys talkin about????
Old Jul 1, 2005 | 08:12 AM
EP3_05's Avatar
Default Re: (Adam_11)
There is an oring on the distributor shaft that seals it to the cylinder head and prevents oil from leaking out around the distributor.
Old Jul 1, 2005 | 09:56 AM
Adam_11's Avatar
Default Re: (91civic)
thanks i'll c if thats the prob.... another question which injectors should he be using... cause the stock ones seem to be slower and doesn't engage vtec to great so we changed them to stock Integra injectors and they worked alot better any suggestions
Old Jul 1, 2005 | 10:02 AM
EP3_05's Avatar
All stock honda injectors are the same besides some prelude injectors. The integra and civic injectors both flow 240cc so any OBD1 civic/integra injectors will work since you say he has VTEC I am assuming he swapped in a d16z6.
Old Jul 1, 2005 | 10:22 AM
91civicEX's Avatar
change the pcv. theyre only a couple dollars at kragen
Old Jul 1, 2005 | 10:25 AM
Adam_11's Avatar
Default Re: (91civicLX)
all the PCV stuff is brand new
Adam_11's Avatar
all the PCV stuff is brand new, and yes it is the D16z6 swap.... it just doesn't seem as powerful as it should b
Old Jul 1, 2005 | 11:38 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
what do you mean "fully built"?
there MIGHT be abnormally high pressure. my 13:1 CR D series seeps oil out of oil filler neck and around the seal on the valve cover.
stan
Old Jul 1, 2005 | 11:52 AM
Bunger's Avatar
Default Re: D16 Swap in CRX... to much crank case pressure help!!! (Stan D)
High compression doesn't always mean uber high crank case pressure. If you have oil leaking out everywhere, I would do a leakdown test, you should be under 10% leakdown.
Old Jul 3, 2005 | 03:22 PM
Adam_11's Avatar
Default Re: D16 Swap in CRX... to much crank case pressure help!!! (Bunger)
he planned on goin turbo so i know the whole motor is built top to bottom im just not sure of what he used i kno its got comp cams and cam gear.....
RedstarS2K
Honda S2000
13
Aug 28, 2008 03:45 AM
Sohc Driver
May 27, 2004 06:28 AM
Acuraman918
May 14, 2004 07:14 PM
Acuraman918
May 14, 2004 01:04 PM
b20vtec-hatch
Apr 7, 2004 07:15 AM
