Suspension & Brakes Theory, alignment, spring rates....
tein coilover
Old Jun 30, 2005 | 06:22 AM
lotusvale's Avatar
Default tein coilover
hi,
i'm just deciding whether i should get tein basic or tein ss for my civic.
i'm not really using it for auto-x or anything. just mostly daily driving, and a little bit of good handling.
just wondering, is the spring rate adjustable on the basic? anyone know the spring rate for both basic and ss?
thanks
Old Jun 30, 2005 | 12:52 PM
bad-monkey's Avatar
Default Re: tein coilover (lotusvale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lotusvale &raquo;</TD></TR><TR><TD CLASS="quote">hi,
thanks</TD></TR></TABLE>
spring rate is never adjustable. you can switch springs and get different rates, but you cannot change spring rates by turning a ****.
get the SS. both kits are garbage, but the SS will probably be a little bit more satisfying than the basics.
spring rates on the SS are 9kg/4kg. not sure what they are on the basics.
Old Jun 30, 2005 | 06:48 PM
lotusvale's Avatar
Default Re: tein coilover (bad-monkey)
cool.. thanks
what other coilover u recommend that is not too stiff but not too soft that if 4 people in the car, it won't go down that much?
Old Jun 30, 2005 | 11:02 PM
Bart-EK's Avatar
if you want Tein, go Flex... SS is WAY too soft for anything... Flex isn't even that hard.
for a DD: check what most people have that won't cost you an arm and a leg!
Old Jul 1, 2005 | 06:33 AM
lotusvale's Avatar
Default Re: (Bart-EK)
i've heard many good things about flex, but it's way out of my budget.
when people say the rate is 235F/140R, is that in lb? like...what's the metric for that?
thanks
Old Jul 1, 2005 | 09:41 AM
bad-monkey's Avatar
Default Re: (lotusvale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lotusvale &raquo;</TD></TR><TR><TD CLASS="quote">i've heard many good things about flex, but it's way out of my budget.
Yeah that's a lb measurement of spring rate. metric equivalent will be the lb/56.
therefore 235/140 is like 4kg/2kg.
as far as the street goes, i'd be on ground controls with koni yellows and spring rates in the 350/300 range. if the car was pulling double duty (a/x or track and daily driving) i'd step it up to a 375/450 or a 425/500 depending on what kind of car you have and how much roughness you can stomach.
the GC/koni setup will cost you about 800 bucks-roughly the same price as the SS, with much better dampers and the same ride ht. adjustability.
Rob.
Jan 21, 2006 09:56 AM
Two_K Si
May 25, 2004 10:55 PM
vti444
Dec 8, 2003 02:07 PM
Paluce
Feb 26, 2003 08:30 AM
