Need help separating tranny housing
Old Jun 29, 2005 | 07:00 PM
hondapwr's Avatar
Default Need help separating tranny housing
I've removed every bolt in the housing except for one that requires a hex key. I still can't get the two pieces apart. Can someone tell me the trick to getting it apart easily? It's a Y21 tranny from a B16A.
Thanks!
Old Jun 29, 2005 | 07:48 PM
Kyles ej1's Avatar
Default Re: Need help separating tranny housing (hondapwr)
pry bar or big screw driver, patience and/or muscle
Old Jun 29, 2005 | 08:58 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
all transmissions have a retaining clip under a hex plug at the very end of the tranny.
its internaly clamping, so you'll have to hold it open, while you pull the outter housing off...
let me see if i can get a pic.
Old Jun 29, 2005 | 08:59 PM
Crasian's Avatar
make sure to take off the starter too that was my problem with my d series
Old Jun 29, 2005 | 09:00 PM
Built B16A's Avatar
Default Re: Need help separating tranny housing (Built B16A)
there ya go....
Old Jun 29, 2005 | 09:01 PM
Built B16A's Avatar
wait?
seperating the housing of the transmission.. or trying to get it off the engine?
and yes.. i'll admit, a few times i left the starter in, and ended up bitting me in the ***.
Old Jun 29, 2005 | 09:26 PM
Crasian's Avatar
oOOOOooo, i thought he wastalking bout taking the engine off the tranny but it says taking apart the housing.... my bad :D
Old Jun 30, 2005 | 04:41 AM
EE_Chris's Avatar
Default Re: (Crasian)
Are you keeping Part 12 spread with some snap-ring pliers while trying to seperate the tranny halves?
Old Jun 30, 2005 | 04:51 AM
Ricey McRicerton's Avatar
Default Re: (EE_Chris)
It took me the better part of a half hour even with a second set of hands to get my first one open. That retaining clip sucks so bad.
Old Jun 30, 2005 | 05:23 AM
EE_Chris's Avatar
Default Re: (Ricey McRicerton)
Yeah - it does. Took a second set of hands and some choice words before we got it apart too.
Old Jun 30, 2005 | 05:36 AM
hondapwr's Avatar
The tranny is out of the car, starter removed, VSS removed, all bolts removed.
So you're saying I just gotta hold that clip open while trying to pry it apart? (Thanks for the diagram)
I'll check my toolbox to see if I have any choice words left that I haven't already tried...
Old Jun 30, 2005 | 05:59 AM
BoostedEG6's Avatar
Default Re: (hondapwr)
also check the side of the tranny, there are two bolts that have springs inside of them with a ball bearing and that will also keep it from coming out along with the retaining clip
Old Jun 30, 2005 | 06:11 AM
nocturnaldragon's Avatar
When I did my first one, I ended up cutting the housing to pieces to get that bitch out. The housing was toast anyway so it dident matter I was only interested in saving the gears.
See my tranny post for pics of the destruction.
Anyhow yes that thing is a MAJOR PAIN in the ***!
Old Jun 30, 2005 | 06:34 AM
EE_Chris's Avatar
Come to think of it, I think I used a long pair of needle nose pliers, as the snap ring pliers weren't working very well. Just use the outside of the nose and pry apart as far as you can. The snap ring pliers have little tips that fit in those holes and then you squeeze them together which in turn spreads the snap ring but it just didn't spread it far enough.
And also make sure to remove the shift detent ***** and springs, as mentioned.
I forgot to ask, but have you even got them seperated at all? The snap ring will keep them from becoming totally seperated but the case halves will still seperate about an 1", maybe less, before you get to the point where you have to mess with the snap ring.
I remember the Hondabond keeping the case halved glued together a little - I used a putty knife to sort of slice through the Hondabond before actually moving ahead with pulling them fully apart too.
Upon re-assembly, here is a tip: When you get the tranny halves back together as far as they can go and then you get that snap ring onto the countershaft bearing as far as it will go, you'll soon see that's it pretty hard to fully seat that ring in the countershaft bearing groove. So get it on as far as it will go - at this point, tension will be holding it in place. Turn the tranny over and drop it onto a piece of wood about 2-3" off the ground - instantly seats it.
Old Jun 30, 2005 | 11:43 AM
hondapwr's Avatar
Yes I took out the two spring bolts and bearings.
It won't separate at all, so I'll try cutting the HondaBond with a knife as you suggested. The snap ring was inside a port that I unscrewed with a 1/2 inch ratchet, there is also something right next to it that requires a large hex key, do I need to remove that too?
I won't be reassembling the tranny. I think the phantom grip came apart inside and cracked the housing. I just want to get it apart to inspect the damage and collect the good parts.
Old Jun 30, 2005 | 12:24 PM
EE_Chris's Avatar
The snap ring behind that big cover you unscrewed with a 1/2 drive ratchet should have been it.
Old Jul 2, 2005 | 07:18 PM
hondapwr's Avatar
Success!!
Old Jul 2, 2005 | 07:23 PM
hondapwr's Avatar
I would like to note that I was able to get it apart more easily by tapping on the mainshaft with a hammer, before messing with the snap ring.
SkertySkerty
May 1, 2007 09:26 AM
Boostedb20EH2
25
Mar 26, 2007 06:46 AM
crexer
Oct 10, 2004 04:15 PM
Tyson
Apr 22, 2004 06:20 PM
gumbybum
Jan 31, 2003 12:25 AM
