my amp....
we'll i have a 1000watt crunch amp..powering my 2 type r alpine subs...it bumps great but sometimes it cuts off the power and there is no bump...i can feel taht the amp is really hot...does this always happen??
Yeah the amp will shut off if it gets too hot. Its a safety built into the amp. Where is the amp located. mount it where it can consumer fresh air to cool down. and also the new crunch amp line is shitty in my opiion. not very well made.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELshow »</TD></TR><TR><TD CLASS="quote">we'll i have a 1000watt crunch amp..powering my 2 type r alpine subs...it bumps great but sometimes it cuts off the power and there is no bump...i can feel taht the amp is really hot...does this always happen??</TD></TR></TABLE>What "Crunch" amp and what Alpine Type R subs. how are the subs wired, [what is the final impedance] is it 2ohms, is the amp stable at 2ohms? what kind of power and ground do you have for your "1000 watt" amp?
94
94
Are you sure about the amps model number? I cant find it on there site, is it an older amp? Is it a 2ch or is it a mono block? Still need to know what the model number of the Alpine Type R subs are. SWR-1021D, 1022D, 1041D or 1042D
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELshow »</TD></TR><TR><TD CLASS="quote">yea it's an older amp..i'm thinking it's mono block cuz i can't bridge it....then i forgot the model # for the subs...</TD></TR></TABLE>Well checking the specs on the new amps it says they are stable to 1 ohm, so if that's the case, [and you have a 2 ohm load] low impedance is not the problem, but I would check anyway, the other thing that can cause an amp to get hot enough for the thermo to shut the amp down is a lack of power, lack of power can be caused by a number of things, poor connections, inadequate power and/or ground wire size, even a bad fuse or fuse type, so check all the connections on the power and ground cables, pay close attention to the amp ground. Have you upgraded the ground at the batt.? What gage is the power and ground wire? Try this, after running the system to the point of shut down, grab ahold of the fuse holder on the power wire by the batt, and the power and ground wire by the amp, check and see if they are hot, be very careful, if the problem is resistance, the fuse holder and/or the wire can get very HOT, hot enough to burn, I have seen plastic fuse holders melted to sludge because of resistance and the amount of current going through the fuse.
94
94
redteg1
Audio / Security / Video
Apr 9, 2002 08:46 PM
