fuel pressure suggestions
i have rc 500
it's gotta be fuel cause if i crank the engine over with no spark then hook spark up it will start fine and run till the mixture and or turbo starts to spool which causes a lean mix ,
i broke the motor in with thecharge pipe disconnected and had bout 25 psi and the car ran fine
