MY SPEEDOMETER IS NOT WORKING
Old Jun 29, 2005 | 12:39 PM
GSR95DXHATCH92's Avatar
Default MY SPEEDOMETER IS NOT WORKING
HELLO I AM HAVEING A SMALL PROBLEM I JUST CHANGED OUT MY DASH ON MY EG AND PUT IN AN INTEG WITH AN OBD1 INTEGRA CLUSTER WITH THE OBD1 WIREING AND EVERY THING WORKS BUT MY SPEEDOMETER IT IS NOT THE GAUGE CLUSTER I TOOK THE ON OUT OF MY INTEG AND SAME PROB
CAN ANYONE HELP?
Old Jun 29, 2005 | 07:20 PM
blackeg's Avatar
Default Re: MY SPEEDOMETER IS NOT WORKING (GSR95DXHATCH92)
its your vehicle speed sensor. more than likely the connection has gone bad. check it out, its located on the top of the trans below the throttle body
Old Jun 29, 2005 | 07:36 PM
neutron91's Avatar
Default Re: MY SPEEDOMETER IS NOT WORKING (blackeg)
jesus christ!... another speedo topic!...
Old Jun 29, 2005 | 10:14 PM
peacexisxfree's Avatar
blackeg is right. find out where to fill your tranny when you're changing out your vss. this wasn't in any searched you performed?
Old Jun 29, 2005 | 10:22 PM
deeksmooth's Avatar
Default Re: (peacexisxfree)
its one of 2 things..
1) you started the car, hit the gas while out of gear and the RPM moved, Gas needle went where it belonged, temp needle moved eventually... but speedo never went anywhere
2) the VSS is fuqued or connection is bad..
i hope its the ladder....
EG94dude
Honda CR-V & Element
Sep 15, 2011 08:23 AM
balistik
Jan 6, 2010 07:17 AM
joethejoeman
Jan 18, 2007 04:50 PM
AzntstyleZ
Mar 29, 2005 09:25 PM
importimage
Jul 26, 2003 10:53 PM
