ABS LIGHT Weird Problem
Old Jun 29, 2005 | 09:45 AM
94AccrdEX's Avatar
Default ABS LIGHT Wont TURN OFF
hey guys i got a 1994 accord ex and for some reason when im put the car in gear and start to go around 2200 rpms the abs light turns on and dos it till i turn the car off but it dosnt happen when im in reverse. If anyone may know it could be please help......
Modified by 94AccrdEX at 7:04 PM 6/29/2005
Modified by 94AccrdEX at 7:14 PM 6/29/2005
Old Jun 29, 2005 | 10:27 PM
94AccrdEX's Avatar
Default Re: ABS LIGHT Wont TURN OFF (94AccrdEX)
hey guys just wanted to bring it to the top incase anyone knows anything thanks
Old Jun 30, 2005 | 04:08 AM
JimBlake's Avatar
What error code does it throw? Read ABS codes just like ECU codes, except it's the ABS light that flashes.
Old Jun 30, 2005 | 12:13 PM
94AccrdEX's Avatar
its not that it flashes it does stays on once i get to around 2000rpms and just stays on no flashing
Old Jun 30, 2005 | 12:34 PM
jb.'s Avatar
jb.
he is talking about jumping the abs plug that is right next to the ecu one. use a paper clip and jump the pins. the light will flash giving you a code that you can look up on HT
Old Jun 30, 2005 | 03:02 PM
94AccrdEX's Avatar
crap i have know idea what you are talking about i dont know alot about elctrical crap
Old Jun 30, 2005 | 03:38 PM
deserthonda's Avatar
Default Re: ABS LIGHT Wont TURN OFF (jbkiksass69)
jumping the abs plug??????? next to the ecu plug??? what are you talking about man..... ..you get abs codes by jumping the same plug as getting engine codes the service chk connector rt side under glove box 2 wires plug
yo 94 accord you better off take to shop if you are not mechanically inclined
Old Jul 9, 2005 | 04:36 PM
94AccrdEX's Avatar
ok cool man thanks i just sux at eltrically problems
Old Jul 10, 2005 | 08:52 PM
94AccrdEX's Avatar
i guess i will have my friend look at the post i reall dont know whats up so i if you vould just expalin in high detaiol and i will have my friebnd read it over thank you
Old Jul 10, 2005 | 09:58 PM
95ACM's Avatar
Go here, it's for the CEL but same directions apply. BTW deserthonda is #1.
http://www.dhost.info/accordinfo/howto/cel.html
Old Jul 11, 2005 | 04:15 AM
JimBlake's Avatar
Default Re: ABS LIGHT Wont TURN OFF (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">jumping the abs plug??????? next to the ecu plug??? what are you talking about man..... ..you get abs codes by jumping the same plug as getting engine codes the service chk connector rt side under glove box 2 wires plug
yo 94 accord you better off take to shop if you are not mechanically inclined</TD></TR></TABLE>I've heard other people claim there's a 2nd plug for ABS in older Accords, but since I don't have one I never knew for sure. Is it always the same plug? I do know the plug location & the list of ABS codes is different for certain years.
Old Jul 11, 2005 | 06:15 AM
jb.'s Avatar
jb.
Default Re: ABS LIGHT Wont TURN OFF (JimBlake)
yeah on my 95 ex, there are two separate plugs under the glove box. they both have blue snap in covers, and one is larger than the other. The larger one is the ecu connector, and the small one is the abs code connector. i will try to get a pic or something later on
Old Jul 11, 2005 | 10:47 AM
JimBlake's Avatar
My '95 Integra had 2 plugs, but only one of them was used for the flashing-light method. Jumper it & read both ECU & ABS codes. The 2nd plug was a connection for a code reader of some kind (pre-OBD-2).
Tonyl507
Mar 13, 2011 07:45 PM
M2nR
Mar 26, 2005 03:34 PM
iLUVmyACCORD
Jan 14, 2005 06:13 AM
pearlteg
Jul 6, 2004 05:32 PM
Undercover_Skank
Mar 15, 2004 07:13 AM
