P75 throwing code 21 and 22 (vtec solenoid and vtec malfunction)
Old Jun 29, 2005 | 09:12 AM
AllMotr's Avatar
Default P75 throwing code 21 and 22 (vtec solenoid and vtec malfunction)
I am a technician at a honda in canada and i have a EG 4dr civic with a 94+ integra ls engine. The car runs good above 2000rpm but has a hesitation before(little bit of a miss fire) and i get a mil comeing on right away apon startup with code 21 and 22 which is vtec but the ecu is a virgin(not socketed), any info would be much appreciated TY.
Old Jun 29, 2005 | 10:09 AM
Phatch99's Avatar
Default Re: P75 throwing code 21 and 22 (AllMotr)
isn't a p75 a ls 95 ls ecu? how can it throw vtec codes if the ecu is a virgin ls ecu?
Old Jun 29, 2005 | 10:24 AM
AllMotr's Avatar
Default Re: P75 throwing code 21 and 22 (Phatch99)
thats what i would like to know. There is no signs i should say that this ecu has been modded, but there is no chip or chip harness, but still throwing codes 21 and 22, car is a EX model(cdn)
Old Jun 29, 2005 | 10:30 AM
mmuller's Avatar
Mad Scientist
no way; your checking the codes wrong most likely
Old Jun 29, 2005 | 11:49 AM
AllMotr's Avatar
Default Re: P75 throwing code 21 and 22 (mmuller)
how am i checking the codes wrong, there is a 2 prong connector on the right side dash and i have a honda tool for it(jumper harness from honda), and the code is 21 and 22. so plz don't tell me i am doing this wrong cause i have been working on hondas for the past 7 years. i get 2 long blinks then 1 quick 1, then 2 long and then2 quick 1s, ur telling me thats not 21 and 22.
Old Jun 29, 2005 | 01:14 PM
hAILO's Avatar
Does canda EX have vtec or is that called an sir or somthing....
Old Jun 29, 2005 | 01:21 PM
AllMotr's Avatar
Default Re: P75 throwing code 21 and 22 (hAILO)
Canadian EX is U.S LX model.
Old Jun 29, 2005 | 06:05 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotr &raquo;</TD></TR><TR><TD CLASS="quote"> so plz don't tell me i am doing this wrong cause i have been working on hondas for the past 7 years. i get 2 long blinks then 1 quick 1, then 2 long and then2 quick 1s, ur telling me thats not 21 and 22.</TD></TR></TABLE>
oh oh.. should i take my hat of to you?
A P75 Ecu can not physically throw codes for vtec, it does not have the hardware to do it. Unless of course it was converted or the rom looks for vtec hardware where there is none.
here is a little write up for a p75 to vtec; look to see if you see and hardware changes on your ecu;
http://forum.pgmfi.org/viewtop...light=
Old Jun 30, 2005 | 05:57 AM
AllMotr's Avatar
no i don't want u to take ur hat off for me i just want ppl to relpy that can help me, i am very confussed that a non vtec setup throws a vtec code, and this is the 2nd ecu that was swapped in.
Old Jul 2, 2005 | 05:34 PM
asefi944's Avatar
y ask noob techs...if ur a honda tech urself we should be askin u these questions
Old Jul 2, 2005 | 07:14 PM
slomofo's Avatar
GDD Member
I think you're either looking up the wrong codes or counting wrong.
I'm also a tech, but instead of just honda, I do all European except Jaguar/Land Rover/Exotics, all japanese, all american, and all korean. Why don't you find a REAL technician to pull codes through the 3 pin connector that's next to the 2 pin. The 3 pin connector does more than just blinking the light. It will save you more time than waiting for the internet to respond to you.
xamdam67
35
Jul 11, 2019 06:32 PM
-Todd-
Jan 31, 2006 05:42 AM
ESPTUNING
May 11, 2005 08:08 AM
gots_a_sol
Aug 4, 2004 05:32 PM
EGh22aEG
Mar 18, 2002 04:18 PM
