removing si front bumper
Old Jun 29, 2005 | 08:47 AM
vancoland's Avatar
Default removing si front bumper
I took off the 7 clips thats located on the top of the bumper, one screw from each side of the wheel well, and the 2 bolts located under the bumper. I been trying to get that bitch off for about 2 hours and it still wouldn't budge...tried to take off headlights to see if there are bolts in between...but you can't get to the hidden located in the fender well...so i tried to take off the fender but theres a hidden bolt or screw somewhere and now everything looking like its interconnected...help people, 2000 si
Old Jun 29, 2005 | 08:56 AM
CardDealer's Avatar
Banned
Default Re: removing si front bumper (vancoland)
Modified by CardDealer at 4:50 PM 11/16/2006
Old Jun 29, 2005 | 09:11 AM
BlueBalls's Avatar
are you sure you got the correct screws off the bottom of the car? there's two phillips head screwdrivers on the bottom of the car. The two bolts attach the bumper to front fenders at the wheel well. just make sure you got the right ones and you should be able to just slide the whole thing out.
Old Jun 29, 2005 | 09:28 AM
BlueBalls's Avatar
Default Re: removing si front bumper (BlueBalls)
this might help:
Old Jun 29, 2005 | 09:45 AM
CaponeGotti's Avatar
i know those philips by the wheel well are 5/16 if that helps hard to get a screw driver up there
Old Jun 29, 2005 | 09:59 AM
vancoland's Avatar
Im pretty sure I removed every bolt and screws listed...7 clips at the top, 2 for the fender wells connected to the bumber...and everything on the bottom of the car that looks like its connect to the bumper...but its not budging.
The strong points where it seems to be still holding is by the lights. Since there is all kinds of plastic pieces blocking my view from looking up under the car...I can't see whats keeping the bumper from coming out
oh...that picture up there...I can't see shiet...its so small, can you make it larger?
Old Jun 29, 2005 | 10:07 AM
Tim.'s Avatar
there are little hangers that don't allow the bumper from coming straight off. you have to pull up on it a litle bit, and then out.
Old Jun 29, 2005 | 10:37 AM
Jon V's Avatar
Default Re: (spoon0313)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon0313 &raquo;</TD></TR><TR><TD CLASS="quote">there are little hangers that don't allow the bumper from coming straight off. you have to pull up on it a litle bit, and then out.</TD></TR></TABLE>
They are on eth very back corners of the bumper towards the wheel wells. you have to lift up on the corners and pop them off of the little rings. there is a small hole in each side of the bumper and them a little piece that goes in to teh holes, so you ahve to lift the bumper up.
and i think there is 4 screws/bolts that you have to take off from under the front nose...
B16HelpMe
Mar 4, 2007 06:52 PM
aeboync
Jan 7, 2006 05:24 PM
Ef Whore
Mar 12, 2003 01:35 PM
ThaOnlyStunna03
Jan 6, 2003 07:33 PM
Quik89Si
Apr 17, 2002 11:01 AM
