vss (code 17)
im getting code 17 on my 88 hatchback dx....so i narrrowed it down to either these 3 items...speed sensor...speedo cable....cluster....ok i bought a 89 crx si cluster and vss last night...so i try on the cluster and nothing...still getting code 17....but the weird thing is that my rpm is bouncing around, the gas and temp gauges dont work well...the temp goes up a little after a while but the fuel stays down....also my hi-beam indicator isnt working....so i replaced that bulb with the stock one and nothing still.....did i get a hold of a bad cluster....or will having a bad vss affect the fuel gauge....cuz it doesnt know how fast im going??? also....did i get wrong cluster.....
I think the wiring is different between the hatch and the CRX. It may not work with the cluster.
As to what the previous post said... I think you need to replace your speedo cable from the tranny to the cluster
ok i replaced the vss and changed the cluster and still nothing....should i replace the speedo cable...or do i have a bad tranny....wut should i do...also when i replaced the vss...there was oil in it....do you think that theres oil in the speedocable and its causing it not to spin???
shonnys92si
Mar 13, 2003 06:14 PM
