'88 Honda Civic HB Clutch How-to?
Old Jun 28, 2005 | 10:06 PM
office888's Avatar
Default '88 Honda Civic HB Clutch How-to?
I'm thinking about buying a 1988 Honda Civic Hatchback, $100. The car runs great, but the clutch is bad. Now the question:
I've never changed a clutch out before in my life...Could anyone direct me to a how-to? I'd be buying an Exedy OEM clutch kit with Pressure Plate, Organic Disc, Throwout Bearing, Bushing, and Alignment tool.
Oh yeah, does the Flywheel need to be replaced as well (or resurfaced)? How much does a flywheel resurfacing cost or can I do it myself? I'm not intending on keeping the stock engine for long, will swap to a B16 at a later date with the help of my father.
Thanks,
Richard
Old Jun 28, 2005 | 11:13 PM
Bunger's Avatar
Default Re: '88 Honda Civic HB Clutch How-to? (office888)
Pull the axles, disconnect the shift linkage, pull the starter, drain and drop the trans, unbolt the pressure plate, unbolt the flywheel, take the flywheel to a machine shop to get resurfaced, and then do everything in reverse order to get it back together. Since you've never done it before, it will probably take you 4-5 hours, minus the resurfacing time.
Thats a basic overview, let me know if you need any more detail.
Old Jun 29, 2005 | 04:42 AM
RA122324's Avatar
Let the car cool down. Disconnect the battery. Loosen the lug nuts. Chalk the back wheels. Jack up the front of the car. Put it on jack stands. Then do all the other stuff:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunger &raquo;</TD></TR><TR><TD CLASS="quote">Pull the axles, disconnect the shift linkage, pull the starter, drain and drop the trans, unbolt the pressure plate, unbolt the flywheel, take the flywheel to a machine shop to get resurfaced, and then do everything in reverse order to get it back together. Since you've never done it before, it will probably take you 4-5 hours, minus the resurfacing time.
Thats a basic overview, let me know if you need any more detail.</TD></TR></TABLE>
Old Jun 29, 2005 | 08:26 AM
Bunger's Avatar
Default Re: '88 Honda Civic HB Clutch How-to? (knwldge54)
Ohh come on... its soo much more fun to do it with the wheels on while its on the ground.
Old Jun 29, 2005 | 08:29 AM
D15Bbigred's Avatar
yeah all that , i would reccomend a transmission jack, but have fun
Old Apr 9, 2014 | 09:47 PM
michalbe1's Avatar
any videos on how to change a clutch on 1988 civic
Old Apr 9, 2014 | 09:50 PM
Black R's Avatar
25 Year Member
Use the helms manual.
It's pretty straightforward.
Old Apr 10, 2014 | 12:15 AM
Black R's Avatar
25 Year Member
Just out of curiosity, is this a japan built car?
Old Apr 10, 2014 | 07:02 AM
sleeps's Avatar
If the flywheel has never been changed and or if the clutch was completly worn out its a good idea to change it out, and they are not that expensive.
Old Apr 10, 2014 | 09:01 AM
ef2_civic's Avatar
Oh man for a hundred doll hairs I'll buy it and fix it And then sell it to u if u want. Clutch is a walk in the park
It'll be a nice way to get fimilar with ur new project
Ash J. Williams
Sep 22, 2012 06:56 AM
methanemotorworks
Feb 13, 2006 07:32 PM
Corinthians
Sep 28, 2004 11:46 AM
BoostedIntegra
Jan 15, 2004 07:59 AM
civicracer99
Aug 25, 2003 01:32 PM
