Final Ration 4.7 clutch plate
Old Jun 28, 2005 | 06:07 PM
kayyanne78's Avatar
Default Final Ration 4.7 clutch plate
Hello friends,
I'm using a Civik EK2 swapped to B18C GSR. Have a question about clutch plate. Right now I'm using Type R gearbox (final ratio 4.7) with Exceedy clutch plate. The plate need to be changed. I'm thinking to replace it with original type R clutch plate. The only thing I'm thinking of
Is original type R clutch plate hard to step on as Exceedy plate?
I'm a town driver and facing a lot of traffic jammed. Therefore, I'm thinking to replace my Exceedy (which is hard to step) to original Type R clutch plate (which I assume softer ). Anybody here have any info about this?
Thanks in advace for any opinion...
wajatimur
Old Jun 28, 2005 | 06:30 PM
Luserkid's Avatar
Default Re: Final Ration 4.7 clutch plate (kayyanne78)
Which Excedy do you have?
If i was you i would get whatever i could get seeing as your not in the states. How well is your aftermarket market where your at?
harrykong
Aug 26, 2006 07:14 AM
TurbodCX
Jan 23, 2004 05:03 PM
TurbodCX
Jan 23, 2004 04:01 AM
Qwikrex
10
Aug 29, 2002 06:13 PM
Qwikrex
Aug 29, 2002 12:54 AM
