JRSC stuff - CARB sticker, Boost pressure sensor, 3.4" pulley - Jackson Racing
Old Jun 28, 2005 | 04:22 PM
EnzoSpeed's Avatar
Default JRSC stuff - CARB sticker, Boost pressure sensor, 3.4" pulley - Jackson Racing
Carb sticker is on ebay: http://cgi.ebay.com/ws/eBayISA...:MT:1
Boost pressure sensor - $15
JR 3.4" pulley - $30
The pulley is made for a b-series because it's a 5-rib. But if you actually use it on a b-series charger it will make insane boost, probably over 12psi. So most people use it on a d-series. It will make between 9-10 psi on a d-series charger. But it WON"T fit on a 96-00 civic - I already tried to put it on mine. There isn't enough clreance because the pulley is so wide and it hits the shock tower.
Old Jun 28, 2005 | 07:44 PM
EnzoSpeed's Avatar
Default Re: JRSC stuff - CARB sticker, Boost pressure sensor, 3.4" pulley - Jackson Racing (EnzoSpeed)
bump
Old Jun 28, 2005 | 08:21 PM
95dxhatch's Avatar
i want the pulley. you take paypal?
Old Jun 29, 2005 | 02:18 AM
EnzoSpeed's Avatar
Default Re: (95dxhatch)
Yeah, paypal is preferred.
But the price is low because the pulley looks like crap, aesthetically speaking. The ribs are perfect, which is what matters, but the area around where the nose bolt goes is banged up because the previous owner hit it with a hammer.
Doesn't affect functionality in the least bit, but if you are **** like me, it will bug you. Is that something that would bother you?
Old Jun 30, 2005 | 08:22 PM
EnzoSpeed's Avatar
Default Re: (EnzoSpeed)
As you can see, pulley is dinged up. Ribs are perfect though. Could definitely use a new paint job.
DjBurns
Apr 18, 2007 08:39 PM
vulocity22
May 5, 2006 06:55 AM
suprchrg95
May 17, 2004 01:10 PM
DDD
Oct 7, 2003 08:44 PM
1234
Apr 7, 2003 09:45 AM
