Can it fit?
Old Jun 28, 2005 | 01:32 PM
gottahookup's Avatar
Default Can it fit?
I have an 88 CRX HF and a 1992 Prelude H23a motor. I want to put that badass motor in the tiny car. I have heard it can be done but NOBODY has the mounts listed online. Does anyone know where I can find the mounts to put the H23 in place of the old OBD0 motor? I also need to know which axles to use as the prelude axles will most likely be way to long. I know I have to drill the floor out to place the H23 cable transmission and shift linkage lines in so I don't need that advice. I also know about switching over from OBD0. If anyone has done this or heard of it, please let me know, I will greatly appreciate all the valuable info. And please I know alot of 15 year olds that think they know what they are doing have accessibility to these forums, so PLEASE only put advice if you actually know. I have built an H22 in an EG coupe and a K20 in an EK hatch so I think I know a little bit. Thanks for your help.
Old Jun 28, 2005 | 01:34 PM
shawn_crx's Avatar
Default Re: Can it fit? (gottahookup)
search.
Most likely it's the same swap as a H22
Old Jun 28, 2005 | 01:39 PM
dh's Avatar
dh
Default Re: Can it fit? (shawn_crx)
I think you have to custom fab B series mounts to fit. Then you'd have to use DA axles. Alot of work...
93preludehoff
Apr 14, 2011 12:10 PM
h22_crx
Jan 19, 2007 04:10 PM
RYan McG.
Apr 4, 2006 10:30 AM
newskoolhatch
May 11, 2003 07:03 AM
loclowd
Aug 19, 2002 12:15 PM
