how to change shoes
Old Jun 28, 2005 | 10:14 AM
antivic's Avatar
Default how to change shoes
i've tried searching and i can't find my civic manual...anyone have a link on how to change the shoes ona civic...i don't have the money for discs, so i need something for temporary
Old Jun 28, 2005 | 10:30 AM
Deemeetree's Avatar
Electrician
Here is 1 link I found on the Search function:
https://honda-tech.com/zerothread?id=270782
From the Helms:
1. Remove tension pins by pushing the retainer springs and turning them.
2. Lower the brake shoe assembly and remove the lower return spring.
3. Remove brake shoe assembly.
4. Disconnect parking brake cable from the parking brake lever.
5. Remove upper return spring, self-adjuster lever and self-adjuster spring. Separate brake shoes.
6. Remove wave washer, parking brake lever and pivot pin from brake shoe by removing u-clip.
Assembly:
1. Place grease to the sliding surface of pivot pin. Insert into brake shoe.
2. Install parking brake lever and wave washer on the pivot pin and secure with the u-clip.
3. Connect parking brake cable to the parking brake lever.
4. Apply grease on all sliding surface.
5. Clean threaded clevises with grease. Adjust with the adjuster bolt.
6. Hook adjuster spring to adjuster lever first, then to the brake shoe.
7. Install clevises and upper return spring.
8. Install lower return spring.
9. Install tension pins and retaining springs.
10. Install brake drum.
Of course, this doesn't help without pics, but you get the idea.
IMO, go and get yourself a Chilton's Manual at least from your local auto store.
Old Jun 28, 2005 | 10:31 AM
Archidictus's Avatar
Unceasing Measure
Default Re: how to change shoes (antivic)
Make sure your e-brake is off, remove the drums, adjust the shoes down with the mechanism in the top center of the assembly, remove old shoes, replace with new shoes, replace drum, pump e-brake, drive away.
That said, unless you have like 200,000 miles, changing your shoes probably won't make a dick's worth of difference.
Old Jun 28, 2005 | 10:48 AM
91civicEX's Avatar
Default Re: how to change shoes (Archidictus)
make sure you do only one side at a time so if you forget how somethin goes together u can look at the other side
Old Jun 28, 2005 | 10:51 AM
Deemeetree's Avatar
Electrician
Default Re: how to change shoes (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">make sure you do only one side at a time so if you forget how somethin goes together u can look at the other side</TD></TR></TABLE>
That's what manuals are for.
bopbop93030
Apr 14, 2009 08:35 AM
hondabadtoy
Jun 10, 2008 11:42 AM
civicd15b2
Mar 29, 2005 02:40 PM
turboD16
Sep 4, 2002 08:44 PM
