15/16 Master Cylinder Upgrade
Old Jun 28, 2005 | 06:21 AM
Rob.'s Avatar
Default 15/16 Master Cylinder Upgrade
I have to get a new master cylinder for my 1991 Crx Si . I was wondering which cars have a 15/16 MC that bolts right up to the existing booster on my crx. I am in Canada and we did not ge a 4 door civic EX Model..
Is there any other car that came with a 15/16 MC ?
thanks
PS: I FOUND THIS PIC , THE MC LOOKS BIGGER, ( FROM 1989 2.0 SI PRELUDE)
I read you have to bend 1 of the lines to make it fit..
Will it work on my crx since mine has 4 wheel disc brakes ?
Modified by Rob. at 9:56 AM 6/28/2005
Old Jun 28, 2005 | 08:55 AM
Rob.'s Avatar
Default Re: 15/16 Master Cylinder Upgrade (Rob.)
up
Old Jun 28, 2005 | 08:57 AM
EFSiR's Avatar
yes, just get the prop valve, if going with front integra brakes, use integra 4040 prop valve, if just changing the rears for discs, use crx 4020 which I have for sale
Old Jun 28, 2005 | 09:01 AM
Rob.'s Avatar
Default Re: 15/16 Master Cylinder Upgrade (EFSiR)
What ? dont I just change the MC ?
Old Jun 28, 2005 | 09:18 AM
XJamesX's Avatar
Yes you already have 4 wheel discs so there is no need to change prop valves. you already have the 40/40. the prelude M/C will work fine.
-James-
Old Jun 28, 2005 | 09:20 AM
Rob.'s Avatar
Default Re: 15/16 Master Cylinder Upgrade (B18C5crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5crx &raquo;</TD></TR><TR><TD CLASS="quote">Yes you already have 4 wheel discs so there is no need to change prop valves. you already have the 40/40. the prelude M/C will work fine.
-James-</TD></TR></TABLE>
YOU DA BEST ! THX
Old Jun 28, 2005 | 09:26 AM
dr_latino999's Avatar
You have to bend the line furthest from the booster, it is some what of a PITA due to proximity of the shock tower.
Old Jun 28, 2005 | 09:28 AM
Rob.'s Avatar
Default Re: 15/16 Master Cylinder Upgrade (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">You have to bend the line furthest from the booster, it is some what of a PITA due to proximity of the shock tower.</TD></TR></TABLE>
thanks.. I read about it here: http://thezam.org/kam/preludemc.html
sedrohatchstyle
16
Aug 21, 2011 06:00 PM
boosted91crx
Apr 10, 2008 06:05 PM
CXHatchback
Jul 17, 2003 09:57 PM
Bnjmn
10
Dec 8, 2002 03:08 PM
