15/16 Master Cylinder Upgrade
I have to get a new master cylinder for my 1991 Crx Si . I was wondering which cars have a 15/16 MC that bolts right up to the existing booster on my crx. I am in Canada and we did not ge a 4 door civic EX Model..
Is there any other car that came with a 15/16 MC ?
thanks
PS: I FOUND THIS PIC , THE MC LOOKS BIGGER, ( FROM 1989 2.0 SI PRELUDE)
I read you have to bend 1 of the lines to make it fit..
Will it work on my crx since mine has 4 wheel disc brakes ?
Modified by Rob. at 9:56 AM 6/28/2005
thanks
Re: 15/16 Master Cylinder Upgrade (Rob.)
yes, just get the prop valve, if going with front integra brakes, use integra 4040 prop valve, if just changing the rears for discs, use crx 4020 which I have for sale
Yes you already have 4 wheel discs so there is no need to change prop valves. you already have the 40/40. the prelude M/C will work fine.
-James-
-James-
Re: 15/16 Master Cylinder Upgrade (B18C5crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5crx »</TD></TR><TR><TD CLASS="quote">Yes you already have 4 wheel discs so there is no need to change prop valves. you already have the 40/40. the prelude M/C will work fine.
-James-</TD></TR></TABLE>
YOU DA BEST ! THX
YOU DA BEST ! THX
Re: 15/16 Master Cylinder Upgrade (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">You have to bend the line furthest from the booster, it is some what of a PITA due to proximity of the shock tower.</TD></TR></TABLE>
thanks.. I read about it here: http://thezam.org/kam/preludemc.html
boosted91crx
04-10-2008 06:05 PM
