LEAKING Sol
Old Jun 27, 2005 | 11:36 PM
JDMSol626's Avatar
Default LEAKING Sol
Whats up...long time reader, first time poster, I got a Sol with some problems but one of them is a LEAK i got coming from the distributor side...My Valve cover gasket isnt leaking, i changed my VTEC Sylenoid Gasket, and i changed my Cam Seal with a billet one from JHPUSA, and i changed the o-ring on the distributor but it seems like there is still oil leaking down the head from behind the distributor and it collects and drips down the front of my motor...any suggestions? I'll post pics up as soon as i can. THANKS!!!
Old Jun 28, 2005 | 01:23 PM
JDMSol626's Avatar
Default Re: LEAKING Sol (JDMSol626)
BUMP for leaking sol
Old Jun 28, 2005 | 01:26 PM
Apocolipse269's Avatar
i had a similar problem and it went away after i changed oil and oil filter...dunno why but bump for exact tech info
Old Jun 28, 2005 | 01:29 PM
Deemeetree's Avatar
Electrician
Should be either the cam seal or distributor o-ring. I had the same problem, turned out to be the distributor o-ring. Can you pin point where the leak is coming from?
Did the distributor look like this:
When you pulled it off?
Old Jun 28, 2005 | 01:32 PM
Stoich EG2's Avatar
Default Re: (Deemeetree)
this happened to me before too. i replaced the o ring and still leaked. open up the dizzy cap to see if there is oil in there. if there is, you CAN get a new seal for the inside (forgot how to describe it) but IMO, just get a new one or something. the reason mine did that though was because i put the dizzy in 180 degrees off but the plugs were in the correct order being 180 degrees off. hope you understood that because i can bearly understand it have a nice day
Old Jun 28, 2005 | 04:20 PM
JDMSol626's Avatar
I dont remeber if the distributor looked like that...imma go take a look right now
Old Jun 28, 2005 | 04:44 PM
JDMSol626's Avatar
Default Re: (JDMSol626)
For those who may be curious...this is a pic of the patient...Yea i know red emblems I had some black ones that looked pretty hard but some No good thieves took em when i parked at the Mall So i threw the red ones back on...got to get some black ones but im broke and the Sol needs attention in other areas.
Old Jun 28, 2005 | 04:48 PM
Brian Hinson's Avatar
Nice sol...
Old Jun 28, 2005 | 04:52 PM
TeamNextGenChris's Avatar
try to look really closely to see exactly where it's coming from.
possibly headgasket leaking?
possibly VTEC solenoid leaking?
doublcheck cam seal and distributor seal?
Chris
Old Jun 28, 2005 | 08:39 PM
JDMSol626's Avatar
Default Re: LEAKING Sol (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian Hinson &raquo;</TD></TR><TR><TD CLASS="quote">Nice sol...</TD></TR></TABLE> Thanks She's my pride and joy despite the hate i get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">try to look really closely to see exactly where it's coming from.
Chris</TD></TR></TABLE>
Its not the VTEC Solenoid..trust thats no leaking at all i sealed that up good
Its not the cam seal cuz i changed it and its not leaking
Im checking out the distributor
And I really hope its not the head gasket cuz im broke and my parents want me to sell the car it has problems but i dont want to get rid of it ever!
THINGS THE SOL NEEDS:
Clutch Slave Cylinder
Brake Booster
Front Lower Ball Joints
Tires
Correct Camber Problem
Knock Sensor
Passenger Side Corner Light
Tires
Old Jun 28, 2005 | 10:23 PM
Toxidomask's Avatar
front of your motor?? it could be the front cam seals if you have a DOHC its common. you sure you did not replace the cam plug seal? the front cam seals are diffrent.
Old Jul 4, 2005 | 07:41 PM
JDMSol626's Avatar
Default Re: LEAKING Sol (Toxidomask)
I finally got around to taking off my distributor and I think i may have loacted the problem...the nice little cracks right?
Old Jul 4, 2005 | 10:50 PM
fizeks's Avatar
bump for this guy and his sol.. i have a similar problem to his but mine leaks from where he describes behind the dizzy or so.. ive changed dizzy seal valve cover seals...etc.. but it still leaks from somewhere but leaks onto the tranny.. i still cant find that leak..
Old Jul 5, 2005 | 08:44 AM
JDMSol626's Avatar
Default LEAKING Sol
Damn I cant stand this leak...Cuz I like to keep my motor clean....
Old Jul 5, 2005 | 12:32 PM
fizeks's Avatar
damn me niether.. if i had my digi i would show u a pic on my tranny i clean it every 2 days another bump for jdmsol
Old Jul 5, 2005 | 11:09 PM
JDMSol626's Avatar
Default Re: (dmxarnold)
Arnold...you are one sick *** fooo! LOL
Old Jul 5, 2005 | 11:12 PM
All Motor Ek99's Avatar
bump for da homie
Old Jul 6, 2005 | 01:23 AM
james p.'s Avatar
free bump for a nice sol!
Old Jul 7, 2005 | 12:07 AM
fizeks's Avatar
Default Re: (james p.)
another bump
eckertd
Aug 29, 2015 04:43 AM
sonson6
Mar 20, 2007 07:56 PM
hatchbro
Oct 13, 2004 09:00 PM
quikrpm'z
Mar 5, 2003 09:41 PM
