Weird clutch/transmission problem?
Old Jun 27, 2005 | 06:02 PM
2jz240z's Avatar
Default Weird clutch/transmission problem?
Hi,
Yesterday on the way home from work I raced a 350z. During the race, I downshifted into 3rd ran it to redline and shifted into 4th, on the 3-4 shift it slipped BAD! and made a horribly pop noise. I put the car into neutral waited for the revs to climb down and attempted to put it into 5th. The car went into gear but when I let the clutch out, the rpms didn't rise or fall, they just acted like they were in netural, like the clutch didn't grab at all.
So I put it into 3rd, same thing, I'm thinking, crap, just grenaded the clutch. So I try light throttle and the clutch grabs, but just barely, anything over light throttle and the clutch slips. I limp the car home and pop the hood to check out the damage, hoping the clutch cable is snapped. To my dismay, its perfectly fine, so I'm pretty sure I need a new clutch.
The weird thing is I can put it in gear easy, and when I slowly let out the pedal it will start to catch without any throttle but it makes a horrible noise like a grinding and it smells like the clutch is burning.
So I have two questions. 1. Its for sure my clutch right? and 2. What clutch will I need? I have a 1989 crx hf with a integra b18a1 and unknown cable tranny. When I bought the car, the guy didn't know what transmission it was. All I know is that its a cable tranny that is very short geared, shorter then a gsr, that bolts to the integra b18a1.
cliff notes: Raced a 350z, blew up my clutch, wondering why it still goes in gear, what clutch I need for my car and how to identify my transmission.
Thanks, Adam
Old Jun 27, 2005 | 06:32 PM
1_QWIK_HF_CRX's Avatar
Default Re: Weird clutch/transmission problem? (2jz240z)
ur pressure plate sounds destroyed while ur at it u better replace ur poilot bearing too. any clutch kit should work unless u want to waist money act is what i had in my dx tranny but i had some power to back it up
Old Jun 27, 2005 | 06:40 PM
2jz240z's Avatar
Default Re: Weird clutch/transmission problem? (1_QWIK_HF_CRX)
Thanks a lot for the reply, thats what I figured about the clutch. Any help on identifying my transmission?
Old Jun 27, 2005 | 07:41 PM
FalkenSiR's Avatar
id plate?
Old Jun 27, 2005 | 08:16 PM
Kwicko's Avatar
Default Re: Weird clutch/transmission problem? (fast88std)
Maybe THIS will help you figure out what transmission and gear ratios you're running.
Mike
Old Jun 27, 2005 | 08:24 PM
Kwicko's Avatar
Default Re: Weird clutch/transmission problem? (Kwicko)
Or maybe THIS ONE.
At a guess, if you're geared shorter than a GSR, I'd say probably you're running a YS1 transmission.
Mike
Old Jun 27, 2005 | 08:46 PM
2jz240z's Avatar
EXCELLENT!!!!!
Thank you so much, I didn't know there was a cable b series transmission, I appreciate the information greatly.
Adam
LS_VTECteggy
Dec 21, 2009 05:22 AM
Street Racer X
Sep 21, 2008 02:35 PM
leono
Oct 14, 2005 09:16 AM
CaTiRo
16
Feb 14, 2004 08:18 PM
TylerC
Jan 13, 2004 01:25 PM
